Go to Post Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. - RoboChair [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #151   Spotlight this post!
Unread 06-01-2010, 20:47
rulesall2 rulesall2 is offline
Team Role: Tactician
rulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud of
Re: 2010 Game Hint #2
Originally Posted by LavastormSW View Post
I agree. If a human player had to stand on/near one of the panels, there's a chance that a robot could potentially hurt them. I see no plexiglass/fence/whatever to prevent that.
Here is a summary of the thread to avoid idea repetition.
The gate and gate location: If both fields (the pictures from above 2009 and 2010) are in fact in proportion, the gate is larger than 2009, in reference to the yellow pads, but the pads could easily be different sizes. There is evidence here about a new beta test gate that was larger: http://www.chiefdelphi.com/media/photos/34329 If you look to see how many "sections" if you will are shown in the render, there are approximately 1.5 on either side of the gate, which means, based on the 2009 field, it would be impossible to determine a location on the field. Possibly, with the hope for more matches, this is a third gate, which isn't a bad idea. The flooring appears to be carpet. The lack of plastic siding/wire: didn't put too much detail for clarity/ they don't exist, and that is part of hint. Finally, the yellow piece is used for safety to stop people from tripping:
2009 yellow:
2010 yellow:
2009 Field: http://farm3.static.flickr.com/2766/...728cf3f6_b.jpg
2010 hint: http://farm3.static.flickr.com/2531/...528ceee8_o.jpg
Hopefully, this will put the kibosh on repeating ideas that have already been discussed/stated.
  #152   Spotlight this post!
Unread 06-01-2010, 20:54
infinitydex's Avatar
infinitydex infinitydex is offline
mr robotics man
AKA: Mr. I DESTROYED U
FRC #2932 (mid pac terminators)
Team Role: Operator
infinitydex will become famous soon enough
Cool Re: 2010 Game Hint #2
READ THIS ITS THE COMPETITION
i learned that the competition is something with shooting like basketball with no baskets or basketballs. its balls like last years competition. the hint #1 is a holder for a ball that is mounted on the wall. if u look closely at hint to the bottom right corner is field and the top right is a wall. its carpet flooring and the yellow things are supports for the field wall, nothing other then that. they had it in last years competition. our team noticed that the steal plate was the loading ramp until some1 say that it was at a 90 degree angle. as we think thats a pivit point so 1+ ball in there and then flip it. also we think that u can shoot teh balls or objects over the wall.
TY
c u at the kick off january 9 2010.
Midpacific team Hawaii
  #153   Spotlight this post!
Unread 06-01-2010, 20:55
mr robotics man
Team Role: Operator
Originally Posted by Spylake View Post
Warming up the bullpen for #2
Since they named the last hint #1 it stands to reason that there should be at least a game hint #2.
y would u even post that
  #154   Spotlight this post!
Unread 06-01-2010, 20:57
viking's Avatar
viking viking is offline
Viking Robotics
AKA: Robert Dudek
FRC #1777 (Viking Robotics)
viking will become famous soon enoughviking will become famous soon enough
I think the hint is telling us:
1. Carpet
2. Same gate configuration - maybe larger
3. 3 gates on each side
4. scorers table moved somewhere else
5. all field elements are on the ends
Viking Robotics Team #1777
2006 FRC Colorado Regional Rookie Inspiration
2007 FRC Greater KC Regional Daimler Chrysler Spirit
2007 FVC St Louis Connect Award
2009 FRC Greater KC Best Website Award
  #155   Spotlight this post!
Unread 06-01-2010, 21:20
Neo1699 Neo1699 is offline
FRC #1699 (Robocats)
Neo1699 is an unknown quantity at this point
Send a message via AIM to Neo1699
Anyone recognize the program that is rendered in? and if so, would that program render clear plexiglass, or would it remain entirely clear? looking at it, there appears to be no plexiglass in the wall, if that is true, then that would imply there is no need to worry about anything escaping the playing field that is smaller than 1.5-2 feet (correct on size if possible)
  #156   Spotlight this post!
Unread 06-01-2010, 21:23
infinitydex does not know the real game. If he did, he would not have come out to say what it is.
He also appears to be a rookie, without proper field setup knowledge. The plate is in fact a loading ramp, with a hinge point at the bend.
  #157   Spotlight this post!
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
TY
Some good ideas you have there, but I don't think that's the actual game. The second hint is a part of the edge around the field, it's not in the middle of it. The 90 degree 'bent' steel plate has a hinge so it stops robots from going off the field when there's a game going on, and folds down afterward to let them pass through, sorta like a door.
Well, I guess we'll find out in less than 3 days... Good luck!
P.S. to everyone else: Don't be pickin' on the rookie teams, guys! We're here to help them get off to a good start. In a way, because they don't know about past field designs, it allows them to come up with some more ideas instead of rehashing old ones over and over.
  #158   Spotlight this post!
Unread 06-01-2010, 21:26
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Let's pretend that we don't know anything about the standard field configuration. If you look at hint 1 and 2 as images (try laying them next to each other, or over the top of each other), you will see:
Both hints have 2 parallel lines
Both hints are oriented in almost the exact same way - approx 45 degrees
Both hints have "something" in the middle of the two lines - hint 1 is the lexan, hint 2 is the gate.
Both hints are CAD renderings
Both hints have the same backgrounds
No clue what the significance is, but I don't believe in coincidences when it comes to the GDC!
Steve
.... so happy Kick-off is in 2 1/2 days (my "Geek Christmas Morning!")
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
  #159   Spotlight this post!
Unread 06-01-2010, 21:27
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Originally Posted by dodar View Post
Just curious but where did you get those pictures from?
I made them in photoshop.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #160   Spotlight this post!
Unread 06-01-2010, 21:28
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by AndyB View Post
In my opinion, the message being communicated is that we are back on carpet this year. I'm curious about the lack of plastic siding, as mentioned before.
That's pretty much what I've determined. Given that it's a picture of a standard field part, there's not much controversy as to what it is. I think that the main points are just the return to carpet (just to relieve some headaches), and possibly the location of the gate. I'm also curious about the lack of plastic siding, though it was probably just either an oversight or it was taken out for clarity purposes.
To me, they look like 2-minute-MS Paint-drawings. One is just colored a little differently.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #161   Spotlight this post!
Unread 06-01-2010, 21:30
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
ok so then for what purpose did you make them and post them in this thread? I am just curious to see the relationship from GH#2 and your pictures
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #162   Spotlight this post!
Unread 06-01-2010, 21:36
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
You are now aware that the pinning rule will return to FIRST.
  #163   Spotlight this post!
Unread 06-01-2010, 21:40
xPaulWallx4 xPaulWallx4 is offline
FRC #0070
xPaulWallx4 is on a distinguished road
Originally Posted by Alan Anderson View Post
Interesting. It looks like a standard FRC field gate, but it is not obviously near the end of the field. Is this a third gate in the middle of the side?
i have a feeling, that it is actually the only entrance onto and off the field. Obviously they would have one on both sides.
  #164   Spotlight this post!
Unread 06-01-2010, 21:41
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Originally Posted by D.Allred View Post
The hint - play faster...
Originally Posted by Pikat View Post
1 minute matches!!!
Anyone remember that in 2001 you got a bonus for finishing early?
Kettering Motorsports
  #165   Spotlight this post!
Unread 06-01-2010, 21:56
wolfie261995 wolfie261995 is offline
FRC #1511
wolfie261995 is an unknown quantity at this point
Three alliances maybe?
[BB] 2010 Game Hint #1 ATannahill Rumor Mill 577 28-03-2010 01:04
[Joke] 2010 Game Hint Greg Needel Rumor Mill 67 24-12-2009 10:30
Game Hint #1 Ice Berg Rumor Mill 898 03-12-2009 20:35
Game Hint #3 SuperJake General Forum 1 29-12-2008 14:59
Game hint #3 garyk General Forum 7 02-01-2008 16:54
