Go to Post P.S. could we get Kanagasabapathy added to the spell check? or will it not handle words that big? :) - Holtzman [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #226   Spotlight this post!
Unread 07-01-2010, 16:23
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: 2010 Game Hint #2
A lot of people have been saying that there won't be regolith this year, and I was myself, but I'm starting to miss it already. With the regolith we didn't have to worry about pinning or ramming penalties and it gave us a chance to really see how robust are robots are.
Also thinking about it now, I know we don't see any regolith in the picture, but would FIRST really get all new flooring for the fields costing them money as well as every team, and then never use it again? I don't think regolith is gone and maybe it won't cover the entire field like it did last year, but it will probably be on some sections of the field. Like how last year for FTC there were certain panels with different properities, like bumpy surfaces and rollers.
Lastly when we're thinking about what the game will be this year don't think there will be some sigh of relief and the game will be easier than last year. That's not why we're in this competition, we're here to challenge ourselves with new and harder problems, and thankfully FIRST has been keeping up with that and challenging us every year.
  #227   Spotlight this post!
Unread 07-01-2010, 16:36
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The regolith was a specific solution to the problem of simulating gravity last year. It was used very hard over many regionals. There was much damage and cracking. Just like the carpets from past seasons it will not be reused.
  #228   Spotlight this post!
Unread 07-01-2010, 16:40
FIRST also uses two rolls of carpet per regional, both for the field. Both arrive new. Neither travels with the field to the next event. Local teams typically get to the carpet to help them run offseasons and other things of that nature.
  #229   Spotlight this post!
Unread 07-01-2010, 16:45
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
The carpet has always been replaced at every event, as was the regolith last year. They have a one and done policy.
Thank-you 294 & 67
www.bobcatrobotics.org
  #230   Spotlight this post!
Unread 07-01-2010, 16:47
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Originally Posted by eagle33199 View Post
I've seen quite a bit of assumptions floated here without much to back them up. For example - how much of the playing field does clue #2 show? To determine this, we'll base it off the official field drawings from last year (http://usfirst.org/roboticsprograms/...aspx?id=11624).
Those drawings dictate that the rail is roughly 18 inches high, and the spacing between the vertical supports is roughly 72 inches - with the exception of the sides next to the ramp (the two fully visible sections in the clue) - those are roughly 49 inches wide.
I agree with you that we should use the best measurement we can find. But disagree with your selection of parts. The three full-sections of rail shown in the image are all the 72-inch length. The gate is now wider than previous years. With the extra rail visible on the ends of the image we have nearly 22 feet of rail visible. That is 40% of the standard field length. Thus we are seeing much more (80%) with symmetry.
The middle 10% of the field could have a stripe on the floor. But there is not much room for a structure like the rack-n-roll tower . . . etc.
Happiest when people tell the truth... However, I am blessed with many friends.
  #231   Spotlight this post!
Unread 07-01-2010, 17:02
IndySam's Avatar
I have opened and closed those gates more times that I could count and they really don't look any bigger to me. Has anyone done the measuring to confirm they are bigger?
  #232   Spotlight this post!
Unread 07-01-2010, 17:12
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Take a look at it again. If we make the (logical) assumption that the side barriers are 18 inches high like they have been in the past, you can't have each section be 72 inches based on the picture - each section would have to be 4 times longer than it is tall, while the picture is clearly closer to 2 times longer than it is tall. You state the gate is wider, but the picture simply doesn't back that up when you start measuring what is shown. in order to be 72 inches wide, the side barriers would have to stand 3 feet tall - much higher than they have in the past. While this is possible (as there's no frame of reference for us in the picture), I'm guessing it's pretty unlikely as it would obstruct the view too much for the audience.
  #233   Spotlight this post!
Unread 07-01-2010, 17:13
Bob Steele's Avatar
AKA: Bob Steele
Originally Posted by Karibou View Post
It's been discussed, and that idea has actually come up several times in the 500-some posts of the thread.
Last year's fish indicated a slippery surface and the idea of the moon. There was plenty of reliability in that, it was simply over-analyzed.
Last year's first hint (the fish) was called a MOONFISH hence the theme for the game...
perhaps the piece in the first hint was simply intended to look like a track,,,
hence some type of train or track theme for this game...
This hint.... not white regolith? carpet perhaps.....or some other dark surface.
Speculation about a hint should never be based on something that is left out of an image.....one can only analyze what IS there in the image..
If we start speculating about a big open field as some have suggested ... we might just as well speculate about a game with no robots...
  #234   Spotlight this post!
Unread 07-01-2010, 17:40
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
  #235   Spotlight this post!
Unread 07-01-2010, 17:43
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
This might have been said already but if you ask me when they posted this hint they intended for it to show us something, and you guys have made excellent guesses but I think that it may be more of an update than a clue.
My thoughts: The layout of these gates are different than last year, for example, they could be on the two long ends of the field (two per a half field) and essentially turning the field sideways and putting players along the long ends, which may or may not add space for three teams to have maybe an opening onto the field (like the Air Lok for moon rocks last year) instead of just two team players using field scoring (again with the moon rocks being scored form behind the wall). Again they probably show a gate to give us a hint, but it might just be saying "hy, we're moving the gates on the field this year."
Just my thoughts. Sorry if it soundd like I was bashing somebody's idea(s).
The system is down.
Rockford Robotics 2039: Think outside the bots.
  #236   Spotlight this post!
Unread 07-01-2010, 17:46
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Tracks? Dark surface that might not be carpet? Game with no robots?
I got it! Introducing the real McCoy 2010 game: Ballast Regulation!
// Don't let my loco motives derail this thread.
Art Dutra IV
世上无难事,只怕有心人.
  #237   Spotlight this post!
Unread 07-01-2010, 17:50
You know, I think that the game theme is going to be parallel.
Think about it. Dave's Morse hints point to telegraph stuff. Telegraph wires were often run in parallel, the better to keep going if one failed. More than that, they ran alongside railroad tracks, the better to maintain them. I have yet to see a train track where the rails aren't parallel, save on the open side of a switch.
Now, Hint #1 shows a device that has parallel rails. It goes on the field somewhere, most likely.
Hint #2 shows a field border, which has parallel rails. Again, it goes on/next to the field.
It's a parallel game. Now to figure out what the parallels are between the hints and the game objects...
  #238   Spotlight this post!
Unread 07-01-2010, 17:52
Prash R.'s Avatar
Prash R. Prash R. is offline
Prash Tank
FRC #0025 (Raider Robotix)
Prash R. is a jewel in the roughPrash R. is a jewel in the roughPrash R. is a jewel in the rough
Send a message via AIM to Prash R.
This is interesting because the gate is placed in a way that we can't see the driver station wall, which is usually visible. Also the gate does look to be a bit wider. So possibly, if the gate is moved closer to the center, we may have less robots on the field, that have larger dimensions. But MOST definitely not 1 v 1 like some were saying. First is trying to speed up games, and not make them last 5 days
  #239   Spotlight this post!
Unread 07-01-2010, 18:10
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
I highly doubt that they will add/subtract teams to the field. I could see a 2v2v2 game, but I don't like the idea when it's painfully obvious that the Red and Blue Alliance could "team up" against the Yellow alliance. Plus having a third team to add to the Elimination bracket would be a pain. Maybe if the field was split up into thirds and there was a robot per alliance to a third, that would get you a "1v1" game
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #240   Spotlight this post!
Unread 07-01-2010, 18:27
IndySam's Avatar
I can't imagine the nightmare of having to cue up three different alliance.
[BB] 2010 Game Hint #1 ATannahill Rumor Mill 577 28-03-2010 01:04
[Joke] 2010 Game Hint Greg Needel Rumor Mill 67 24-12-2009 10:30
Game Hint #1 Ice Berg Rumor Mill 898 03-12-2009 20:35
Game Hint #3 SuperJake General Forum 1 29-12-2008 14:59
Game hint #3 garyk General Forum 7 02-01-2008 16:54
