Go to Post why does everyone think im so violent? - Kim Masi [more]
  #46   Spotlight this post!
Unread 07-01-2010, 20:13
RobertG RobertG is offline
FRC #0294
RobertG will become famous soon enough
Re: Burt Rutan - Is Climate Change caused by Mankind?
Originally Posted by artdutra04 View Post
When one side says A, and the other says B, the truth is usually somewhere in the between.
This may be how politics works, but it is not how science works. As an example take the "debates" over whether vaccines cause autism. Even though the science shows the that there is no link, the media will, or used to, find someone to support the other side. The presence of an opposing viewpoint does not affect an argument's veracity.
Also, I have heard multiple times on the NPR station I listen to that a carbon tax and rebate would be more effective than a cap and trade system. The cap and trade system can be gamed because it rewards reductions in CO2, not the actual amount released, so some businesses might increase their emissions before implementation so that they can later "reduce" them.
Taxing carbon at a rate too low, however, could actually increase emissions, or decrease any current reductions, because it turns the problem of climate change from a social problem(save the planet for our children) to an economic problem(we need to save money be cutting our emissions). The analogy I heard was of a plate of ten cookies. If ten people each want ten cookies, and if the cookies are free people will be mindful and only take one cookie. If, however, the cookies are five cents each, then the first person to find the plate will buy all of them, since he or she thinks that by paying for them he or she does not think he or she is hurting anyone.
  #47   Spotlight this post!
Unread 07-01-2010, 20:20
Unfortunately, global warming and how to stop it have been pushed into the political realm.
The three things I'd most like to see in the entire debate are:
1) Complete data for as far back as there are accurate records of any kind--nobody's been willing to provide that, that I've seen, on either side of the debate
2) As complete data as possible showing how humans and their activities are involved in the warming/cooling/whatever it is
3) A science-based solution, not some apparently random governmental regulation. And by science-based, I mean one that looks at all sides of the issue if possible.
Guess what I have no hope of ever seeing? Yeah, that's right, #1 and #2 above. #3 is a little more hopeful...if the politicians can figure out which one to implement this year.
  #48   Spotlight this post!
Unread 08-01-2010, 14:34
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
While I definitely agree with the anecdote you provided, there is a good deal of debate in science. That's the whole point of peer-reviews. And very rarely is one side of the peer-review journal debates is 100% correct and the other side 100% incorrect.
  #49   Spotlight this post!
Unread 08-01-2010, 23:54
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Mark Rozitis View Post
1. Unplug chargers (think cell phones and iPods) when not in use. Only 5% of the power drawn by a cell phone charger is used to charge the phone. The other 95% is wasted when it is left plugged into the wall.
Not exactly. When the output of a transformer has a high impedance (i.e., it's not connected or drawing any current) the input also sees that high impedance, effectively becoming an open circuit.
You can try this with a Kill-o-watt device, or (if you are supremely careful) with a digital ammeter. Charging, the current is a few milliamps; idle the current falls to the microampere level. 100 uA*120V=.012 Watt, or just over 1 kWh per decade. At 14 cents a kWh, the savings isn't too much.
That doesn't invalidate the idea of unplugging things you don't need to use: A pancil sharpener I have draws 40 mA when idle, do the math on that one!
  #50   Spotlight this post!
Unread 09-01-2010, 00:00
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If it is indeed a problem, and there is indeed something to be done about it, devices that draw several milliwatts are not a significant part of the solution. Societies that stop using gigawatts are.
  #51   Spotlight this post!
Unread 09-01-2010, 13:29
-42-'s Avatar
-42- -42- is offline
Bangs His Head in Polyrythyms
AKA: *****
FRC #1388 (Eagle Robotics)
Team Role: CAD
-42- is an unknown quantity at this point
Send a message via AIM to -42-
I've seen the entire thing. While 'Inconvenient Truth' ruined slideshows for me, Rutan did have his stuff together, and he approached the subject in a way that most do not.
I am a 'skeptic' but I simply find climatalogical data to be of insufficient scale and scope for a true conclusion to be drawn.
Climate-challenged teams? David Brinza General Forum 23 05-01-2009 00:09
What technological advance has caused more harm than good? Koko Ed Math and Science 51 22-05-2005 13:54
Electrical Connector For Climate Control Actuator gail OCCRA 3 20-10-2002 23:20
time change soap108 CD Forum Support 4 08-04-2002 22:56
