Go to Post Maybe if we get lucky [the GDC] will just say chute door. - IronicDeadBird [more]
Unread 07-01-2010, 19:15
linkhyrule5 linkhyrule5 is offline
FRC #1072
linkhyrule5 is an unknown quantity at this point
LabVIEW code deploying instead of running
Heya all!
I'm trying to test my code by running it on my own computer. Unfortunately, it insists on deploying to a nonexistent cRIO. I've tried all the menu options I could find, and I couldn't find a way to stop this. Does anyone know how to turn it off?
Unread 07-01-2010, 20:43
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Thumbs up Re: LabVIEW code deploying instead of running
you are operating in a FRC robot project try opening a blank vi then copying your code there
Unread 07-01-2010, 20:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
See this thread for more info on testing code without a cRIO:
http://www.chiefdelphi.com/forums/sh...t=labview+test
Unread 07-01-2010, 20:55
AKA: Jon
if you are trying to test FRC code then you have to replace inputs with controls or constants and replace the outputs with indicators
Unread 08-01-2010, 13:03
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
In your LabVIEW project move the VI you are trying to run from under the cRIO Tree to under My Computer. This will change the context in which the VI runs. In the bottom left corner of your VI your should see if it is targeted to the cRIO or My Computer.
Note: If the VI is open when you move its location in the project you will have to close and reopen the VI before the change take effect.
Also, you're VI won't work if you have attempting you use hardware resources on the cRIO when in the My Computer context.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 09-01-2010, 23:05
Team843 Team843 is offline
FRC #0843
Team843 is an unknown quantity at this point
You can replace the I/Os with controls n indicators (so that you can control and see your program) and then open the main application instance (so that it wont try and deploy when u run it)
that way u can easily test and simulate the program without having to change your programming architecture
Unread 10-01-2010, 14:57
My advice would be to keep the I/O calls at the higher levels, and call into subVIs passing in the values and possibly passing out values. Doing this means that at the lower levels, you can drag the "logic only" subVIs up to the host and unit test them easily by typing in values, setting break points, etc. Then you drag them back to the cRIO portion of the project.
Greg McKaskle
Issue deploying Code rudun Java 5 18-01-2010 21:24
Having trouble with Deploying code Hatefulhippo Programming 2 15-02-2009 14:02
Proper procedure for deploying Labview code? domoarigato NI LabVIEW 8 03-02-2009 06:52
Problems running Default LabView Code Version 3.0 seg9585 Programming 6 01-02-2009 17:23
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
