Go to Post We have put our [robot] on a treadmill. It should shed those excessive pounds and be in shape to compete.:) - Seth Mallory [more]
Unread 07-01-2010, 21:47
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Is riveting that much better?
Originally Posted by Trent B View Post
That was my thought too. You say they weigh 1/10th of a steel bolt/nut combo. So throw 5 of them on to replace a bolt/nut and you are still under.
If you're trying to join two pieces of 1" aluminum at a 90 degree angle, you may not be able to do that (you would have a 1" x 1" overlap). You could use a 90 degree plate to do the joint and then use lots of rivets, but I would argue that a nut and bolt would be simpler and lighter at that point. I guess my point is, do whatever is simplest (KISS).
Unread 07-01-2010, 22:17
Gdeaver Gdeaver is offline
FRC #1640
Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail.
Unread 07-01-2010, 23:26
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Case in point, for any large pieces of sheet metal (like many of the bots I have seen riveted) more rivets is probably better but I suppose its easier sometimes to bolt things like that together as sheet metal gussets would make it non KISS.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 07-01-2010, 23:50
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
Last year we made this super awesome looking shooter guard for our turret wheel and it took us well into the morning, needless to say we forgot about rivets...
If you can't get a screw in there make sure not to forget about the rivets.
Unread 08-01-2010, 15:29
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Yes, yes it is.
For one thing, as awesome as welding is you are usually going to have two problems:
1) Frame distortion- Every frame I have designed that has been welded has warped to some degree (especially aluminium), this is not a happy thing to deal with (wheel contact, conveyor alignment... ).
2) Skill- My team was lucky to have a veteran welder around, but I have seen what happens when a new student tries to weld aluminium. It becomes more like modern art, and less like robot frame .
Bolts lose in the weight and remaining tight categories.
Rivets are light, easily installed and uninstalled, and create pretty solid joints when done correctly. I think every FRC robot has at least one application where rivets would be the most useful of all fasteners.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 08-01-2010, 16:11
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
im glad to see 1501 is known when it comes to riveting
our team has used over 10,000 rivets on our robots so far, almost 2000 in some robots. They are made out of a monocoque design, which is what aircraft use. solely sheetmetal and rivets, providing a strong structure. i think youll enjoy some photos of our bots.
www.huntingtonrobotics.org
all we use are hand rivet guns and a pneumatic rivet gun (used rarely)... i have spent all nighters riveting the bots together. but it creates an amazing end product. if you would like more info, pm me and i can get it to you. and yes we do make errors, but you can just use the same drill bit you used to make the original whole and drill the rivet back out. almost as if it were never there.
and klekos are a neccessity when building with this many rivets
Unread 08-01-2010, 16:46
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Samir,
The link doesn't seem to be working.
-RC
R.C.
MadTown Robotics Team 1323
Unread 08-01-2010, 17:13
AKA: Samir Shaikh
FRC #4329
lol whoops... thanks squirrel! i got a little ahead of myself... i corrected the link
Unread 08-01-2010, 18:47
College Mentor
AKA: Trent Borman
Since I do not have much experience with rivets, care to explain what the rather large things between the already finished rivets are?
http://www.flickr.com/photos/teamthr...7614958581531/
Are they a tool for putting on solid rivets or something?
Unread 08-01-2010, 18:51
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
They are clamps, more or less.
--Madison--
...down at the Ozdust!
Unread 08-01-2010, 19:18
Aren_Hill's Avatar
Build Nifty Things
those are called Clekos, they serve as a quick insert stand in for a rivet to get things aligned.
Think of them as vice grips for sheet metal joints, they hold everything in line when you start putting in the real rivets.
A guy who likes robots.
Unread 08-01-2010, 20:24
College Mentor
AKA: Trent Borman
So, they clamp it by slipping through the holes so other rivet holes will line up?
Unread 08-01-2010, 20:46
Aren_Hill's Avatar
Build Nifty Things
effectively a stand in rivet, yes
Unread 08-01-2010, 21:06
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
long answer: there are pros and cons of each.
short answer: YES
While I still use bolts for super high shear areas, 90 percent of the fasteners we used last year were rivets. Our entire robot was essentially 1/4" aluminum rivets, 1x1x1/16 aluminum tubing, and 4"x4" aluminum triangles for corner connections. We never had a rivet fail. Removal is easy as pie too, just drill through. Hole enlargement was minimal in my experience since the center of the rivet kept the bit straight.
I think someone said earlier that a team could dissassemble and reassemble a robot faster using rivets than bolts. I have to agree, you just have to drill through and re-rivet. I also hate having to tighten loose nuts so riveting is definitely my favorite.
-Vivek
EDIT: With a good square, you can get perfect 90 degree angles without machined corner braces. We just cut them on a miter saw and clamped everything down to a work bench and lined it up with a square. Make sure your holes are aligned though.
EDIT2: We probably saved a few pounds by using rivets too. They are SOO much easier to maintain. Sorry about the edits, I just really love rivets.
"we don't build robots, we build people"
Unread 08-01-2010, 22:12
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
like most people said rivets are nice for more permanent uses. you have to drill them out if you need to undo the fastening.
i would suggest staying with the nut and bolt, but use locking washers or loctite. Or use the nuts with the nylon in the tips.
Riveting up a frame Billfred Technical Discussion 27 19-12-2006 19:49
Simple things that have made your life better or easier KenWittlief Chit-Chat 15 25-10-2005 06:16
FAHA: Team clothing that adds a bit much girth? Ken Leung General Forum 2 08-04-2004 09:42
Thank you Teams that Give So Much Back to FIRST JamesJones Thanks and/or Congrats 1 30-04-2002 13:43
