Go to Post A good driver will always win over a good robot. - Mike Norton [more]
Unread 08-01-2010, 22:13
Trevor_Decker's Avatar
Trevor_Decker Trevor_Decker is offline
AKA: Trevor Decker
FRC #3504 (Girls of Steel)
Trevor_Decker is an unknown quantity at this point
Re: Accelerometers & Gyros for N00bs
Originally Posted by Chris Hibner View Post
As a side note, if you want to know how far your robot has travelled, you're much better off using encoders.
My problem with encoders is that if the wheels slip then the robot will think that it has moved more than it has.
I am not to concerned about the acceleration being greater then the accelerometer max, since I plain to get one that is between .5 g and 1 g greater then the hiegst acceleration the robot should be moving at, also the date from the accelerometer will probably only be used during the autonomies period, so it only really matters for the first 30 seconds. that being said it would be nice for it to work the whole time, Hopefully giving the drive an on screen birds eye view of the robots position.
- Trevor
Team 3504 - The Girls of Steel 2011 - Present
2012 Pittsburgh Regional Engineering Inspiration, and website awards
Team 1743 - The Short Circuits 2009 - 2011
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2010 Won Autodesk Animation Competition
2010,2011 Pittsburgh Team spirit award
Unread 09-01-2010, 04:26
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Accelerometers and Gyros have other applications than for the drivetrains:
In the 2007 game, where at the end-term of the match (20 seconed before end), you would have to lift up two of your other alliance robots, our team has developed a jack system to lift the two robots.
The robot had two "wings" (flat plates from each side that would open up). In the inner corners of the robot were 4 poles that were attached to a motor (The robot. I'm afarid the good pictuers are gone, but it shows most of the robot). These poles were designed to be pushed downwards (more exactly, rotated downwards) when the motors where activated. At some point all 4 poles would reach the ground, and start pushing the ground, which, thanks to Newtown's third law (If object A exerts a force F on object B, then object B exerts an equal and opposite force –F on object A - http://www-istp.gsfc.nasa.gov/stargaze/Snewton3.htm), would result in the lifting of the robot itself, with the two other robots on each of the plates (overall lifting 2 robots "plus one more").
The major problem we had in our design is that we had only a total of 2 of the main motors we planned to use to rotate the poles, so we were forced to use 2 lesser powerful motors, which would result in that two poles would push the robot earlier than the two others, resulting in the tilting o the two other robots on our plates and thier fall or our poles braking from the pressure of 180 KG.
We resolved on using a 2-axis accelerometer to measure the the tilting to each direction - forwards/backwards and sideways. By integrating the change in each axis, we were able to come up with a mathematical algorithm for sending the correct speed to each motor, in order to compinsate for any tilts that would might have been caused from the varying dimension and weight of the alliance robots.
I've seen a team use a Gyro for thier robot's arm, to measure the rate of change in the arms movements to know what its current position is (by integeration, as described before me).
Note that usually a potentiometer is more effective and easier to use than a Gyro for this kind of arm positioning application. The potentiometer revolves with the arm, and as it revolves, it chances the resistance inside of it, and therefore the voltage that is recieved from it changes also. If the potentionmeter is constant, you get a constant voltage of that position. If your position would change, so would the voltage - even if you would stop in a new position, it would send the voltage for that position, instead of giving you the "rate of change" like the Gyro - no need for integration here in order to know what is your position.
Hope I gave a good lesson.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 09-01-2010, 08:57
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
That's an easy problem to solve - use dummy wheels. In other words, put a wheel on the end of a trailing arm that is lightly spring loaded toward the floor. Hook up the encoder to this wheel. Then if the drivetrain slips, you don't have to worry because this wheel is just an unpowered dummy wheel along for the ride. We've been doing it that way since 2003 and it works perfectly every time. Last year we used two dummy wheels - one on each side of the drivetrain (the dummy wheels were in the same line as the drive wheels). By doing this you can also eliminate the gyro. I'll let you do the math to figure that out.
mounting accelerometers & gyros wireties Electrical 2 26-01-2008 20:10
White Paper Discuss: "18 Tips for in the Pits for FIRST Teams" RoboMom Extra Discussion 2 11-02-2006 19:42
Where to get the KOP accelerometers? Billfred Kit & Additional Hardware 0 19-11-2005 10:15
Teaching n00bs kcy88 3D Animation and Competition 19 08-04-2005 07:00
The accelerometers Validius Programming 9 21-03-2005 08:22
