Go to Post work hard, think hard, and have fun doing it. - ebarker [more]
Unread 08-01-2010, 23:54
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Burt Rutan - Is Climate Change caused by Mankind?
Originally Posted by Mark Rozitis View Post
1. Unplug chargers (think cell phones and iPods) when not in use. Only 5% of the power drawn by a cell phone charger is used to charge the phone. The other 95% is wasted when it is left plugged into the wall.
Not exactly. When the output of a transformer has a high impedance (i.e., it's not connected or drawing any current) the input also sees that high impedance, effectively becoming an open circuit.
You can try this with a Kill-o-watt device, or (if you are supremely careful) with a digital ammeter. Charging, the current is a few milliamps; idle the current falls to the microampere level. 100 uA*120V=.012 Watt, or just over 1 kWh per decade. At 14 cents a kWh, the savings isn't too much.
That doesn't invalidate the idea of unplugging things you don't need to use: A pancil sharpener I have draws 40 mA when idle, do the math on that one!
Climate-challenged teams? David Brinza General Forum 23 05-01-2009 00:09
What technological advance has caused more harm than good? Koko Ed Math and Science 51 22-05-2005 13:54
Electrical Connector For Climate Control Actuator gail OCCRA 3 20-10-2002 23:20
time change soap108 CD Forum Support 4 08-04-2002 22:56
