Go to Post In the end, you get out of FIRST what you put in. - BlueLipstick [more]
Unread 09-01-2010, 12:25
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Possible Discrepency - G17
If you look in section 7.3.4.3 (Handling Balls) at G17, there is a formula for how long you have to put a ball back in play after it has passed through the ball counter. In the blue box below, it explains that you get an additional 4 seconds for each ball in the alliance station before it is returned, but with the formula they have given, you would get four seconds less for each ball. Also, with this formula, you could possibly have a negative amount of time to put a ball back into play. We thought maybe there was a subtraction where there needed to be an addition, but this would give unlimited time. Any explanations or help would be awesome. (especially because we were not able to download the extended explanation) Thanks!
www.sharkattack744.com
Unread 09-01-2010, 12:35
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Possible Discrepency - G17
I had issues with the DOGMA pdf too. was it not accepting your password?
Unread 09-01-2010, 12:50
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
I also can't open the DOGMA pdf, but I had a different interpretation of the formula. The key to understanding the formula is that T_expire and T_score represent times on the countdown clock.
Pretend you score a ball with 1 minute (60 seconds) left on the clock. If there are zero balls waiting to be returned to the field, then this ball must be returned before the clock reads 49 seconds left, because 60 - [11 + (4*0)] = 60 - 11 = 49. If there is already one ball waiting to be returned to the field, then the just-scored ball (now the second ball waiting to be returned to the field) must be returned before the clock reads 45 seconds left, because 60 - [11 + (4*1)] = 60 - 15 = 45. Thus, you have an extra 4 seconds to return this second ball because there's a backlog of balls waiting to be returned.
Unread 09-01-2010, 12:54
samepstein samepstein is offline
FRC #0555 (Montclair Robotics)
samepstein will become famous soon enough
Send a message via AIM to samepstein
Yes, I believe there is an error with the password set for the DOGMA pdf.
Unread 09-01-2010, 13:28
Ekaru Ekaru is offline
FRC #2500
Ekaru is an unknown quantity at this point
As said, the formula gives you 4 more seconds for each ball, no error, due to how the formula works.
Unread 09-01-2010, 13:29
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
this was my understanding as well and i feel that it will be a discussion for the Q&A soon... I also could not get into the DOGMA pdf..
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 09-01-2010, 16:09
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
I don't think there is much discrepency at all. jacobhurwitz explained it pretty well. The key is that t_exp and T-score are the number of seconds left. Therefore, the expected time can be negative because if you get a ball for example with less than 11 seconds remaining, it does not ever need to be put back on the field. Negative times actually do make sense here because they represent the "never" possibility for the time at which a ball must re-enter the field. Hope that helps.
Unread 10-01-2010, 17:27
Thank you, I understand now, I was interpreting it as that t-exp as the amount of time you had to return the ball, not the time by which the ball was returned. Thank you again.
Unread 10-01-2010, 20:52
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
I see the times provided by the formula in rule G17 are the clock times, not the ball return times, but I'm still not clear on how long we have to return the first ball....
When the first ball enters, would n=1?
If so, according to the formula, wouldn't we have 15 seconds to return the ball (not 11 as described in the blue box below the rule)?
Obviously with the penalties associted with holding balls too long, they should be returned to the field ASAP, but just wondering about the math.
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 10-01-2010, 21:15
Nope, it's 11 seconds. n = 0. The second one (if the first one hasn't made it out) would get 15 seconds.
Oh, and if you haven't found this out already, the DOGMA document isn't locked anymore. It's got a really good explanation.
Unread 10-01-2010, 22:32
Engineer/Mentor
AKA: Scott5736
Thanks for the re-confirming n=0 when the first balls passes.
From the way I read it, it would be that n=1 when the first ball is scored, as that is now the "# unexpired balls currently in station" (per DOGMA definition, since I thought "currently" is triggred when it is scored) or per rule G17 that n=1 since that ball has "passed through the ball counter".
I think I've been reading way too many contracts as work lately!!!
In the end, I can see the intent is n=0 for the first ball, so it is what it is.
Unread 10-01-2010, 22:39
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Depending on which side your team is on (the current leader or minor) you may or may not need to remember the code, just each ball in play within 2.5 s. of receiving should be a good set point for a minor alliance or you could remember the formula in case you have the lead and delay the time the balls go in, thus giving the opposition time to score, but again you could just have the formula on your dashboard and multiply adjust it to the amount of balls you're receiving.
I was probably rambling that probably wasn't help but I just want everyone to know there are more options.
EDIT: Tell me in the demonstration the little tunnel over the return rail looked like it had a yellow sensor on top, is that an IR sensor to tell whether the ball is returned? If so I guess the time the ball needs to be returned must be from the time received to the time it takes to go through that tunnel.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 10-01-2010, 22:50
vg674's Avatar
vg674 vg674 is offline
FRC #0118 (Robonauts)
vg674 is an unknown quantity at this point
If I understand correctly, the time starts with the counter in the goal, whatever mechanism it may be, and ends with the counter on the ball return.
The board is a mirror of the mind of the players as the moments pass. When a master studies the record of a game he can tell at what point greed overtook the pupil, when he became tired, when he fell into stupidity, and when the maid came by with tea.
- Anonymous Go player
Unread 10-01-2010, 22:56
You are correct. There is a sensor in the chute from the goal and another over the player station. When a ball comes in, a flag is set for a certain time (based on the formula). When a ball goes out, the next flag is cleared.
And the sensor in the chute (and probably in the return) is a quadrature-encoded photoelectric sensor. (Forget whether that's in Section 6, the field drawings, or the DOGMA document, but it's there.)
Unread 10-01-2010, 22:57
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Here's a few shots from the Kickoff showing the two counting devices:
ID:	8260  Click image for larger version
Discrepency in Countdown for Chairman's George A. Chairman's Award 1 20-02-2008 18:29
G36C discrepency gam3fr3ak1 Rules/Strategy 2 05-01-2008 15:19
Update 4.3.4.3 <g17> Dominicano0519 Rules/Strategy 3 12-03-2006 12:01
Discrepency in standings rollncoast Regional Competitions 8 08-03-2003 21:34
Is it possible... Jon K. CD Forum Support 4 26-08-2002 00:01
