Go to Post In Israel we've got the president supporting FIRST and speaking at events, so it's time for you guys to catch up =] - Tottanka [more]
Unread 09-01-2010, 13:50
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
84 inch diameter vertical right cylindrical volume ?
Does this not make sense to anyone else?
The Finale configuration confuses me. Does this just mean we have to fit in a 90 inch tall by 84 inch diameter cylinder? Or a sphere? If we are tipped does the cylinder rotate?
I've read the manual.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 09-01-2010, 13:52
Matthew2c4u's Avatar
Matthew2c4u Matthew2c4u is offline
AKA: Matt Baker
FRC #1622 (Spyder)
Team Role: Tactician
Matthew2c4u has a spectacular aura aboutMatthew2c4u has a spectacular aura about
Send a message via AIM to Matthew2c4u Send a message via MSN to Matthew2c4u
Re: 84 inch diameter vertical right cylindrical volume ?
When the last 20 seconds of the game are in effect, you cant be outside that size cylinder.
If you get tipped you wont recieve penaltys for being too big.
This year is an "Outside" The box year.
Unread 09-01-2010, 14:03
EricH EricH is online now
Take a soda can. Barring stuff around the base and top, it is a vertical right cylindrical volume. (You could also wrap paper around that can for a better impression.) Now expand it to 90" high and an 84" diameter. Fit in it.
As for the question on tipping, I can't find anything saying tipped robots are penalized for going out of their volume. I also can't find anything the other way. Q&A it and see.
Unread 09-01-2010, 14:08
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
it is slightly confusing, but the cylinder is defined using the robot's coordinate system (flips over with the robot), even thought the cylinder itself is called a 'vertical' right cylindrical volume.
(specifically <R10> During the MATCH, the ROBOT will assume one of two operating configurations. When in each configuration, the ROBOT shall fit within the limits shown below (note: these limits are defined in reference to the ROBOT, not the FIELD). (emphasis mine))
Unread 09-01-2010, 14:38
cjc343 cjc343 is offline
FRC #0481
cjc343 is an unknown quantity at this point
So, does this mean that the final configuration must fit inside a 84" diameter cylinder oriented to the robot's orientation, no more than 90" tall? Or is the 90" height separate from the cylinder which would then vary in height depending on the angle of the cylinder?
Seems like awful wording to me.
Unread 09-01-2010, 14:44
The height is of the cylinder. The height of the box is not separate from the box base (normal configuration). The way it works is with orientation to the robot. Therefore, should the robot tip completely onto one side, it is now in a horizontal right cylinder with a 90" length and an 84" diameter.
Unread 09-01-2010, 14:45
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
the cylinder is always 84" diameter, always 90" tall, the end surfaces are always a circle (no angles involved) and all dimensions are aligned with the robot.
If your robot leans at a 10 degree angle while hanging from the tower, so does your reference cylinder.
Again with the soda can - take said soda can and bolt it to your robot such that it is sitting normally (like on a table) when your robot is on the ground. The reference cylinder is always aligned with the soda can. your robot does not need to be centered in the cylinder, just inside it.
Unread 11-01-2010, 12:43
854 bears 854 bears is offline
None #0854
854 bears will become famous soon enough854 bears will become famous soon enough
I have a question about the placement of this cylinder relative to the robot. I have read through the rules a couple of times, and couldnt find anything to answer my question. What I am wondering is if this cylinder has to be centered relative to the robot base (meaning you have only 42" in all directions to expand), or whether the only requirement is that your robot must fit inside an 84" diameter cylinder (meaning you could expand 84" on one side, but not the other. Any insight or clarification is greatly appreciated.
Thank you,
Team 854
Unread 11-01-2010, 12:47
Chris is me's Avatar
AKA: Pinecone
Thank you,
Team 854
Previous year cylinder rules did not have it centered in the robot base, and nothing in the rules indicates this isn't the case this year.
Unread 11-01-2010, 13:27
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
This year, the FINALE CONFIGURATION appears to be similar to the cylinder limit of 2008, which stated "While in the PLAYING CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80 inches(e.g. all parts of the ROBOT must fit within an imaginary 80-inch-diameter upright cylinder)." (NOTE: This is a rule from the 2008 game that I am merely including for reference)
NOTE: I'll include a disclaimer that this is my interpretation of the current FINALE CONFIGURATION (rule <R10>), and the drawing is not to scale (best I could do in a short time in MS Paint).
Unread 11-01-2010, 13:52
Matt C's Avatar
FRC #1468 (J-Birds)
The rule states it is a "vertical right cylinder", therefore it would not move with the robot, but is stationary. Rule <G30> allows for righting of your robot by allowing them to "expand up to the FINALE CONFIGURATION volume while, and only while, performing the righting operation."
Unread 11-01-2010, 13:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
During the last 20 seconds of the game, but also during the rest of the game if your robot is in contact with the TOWER. So you can get a head start if you need more than 20 seconds, is my guess.
<G30> ROBOT Volume – During a MATCH, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as follows:
c. TOWER Contact ROBOT Volume - During a MATCH, ROBOTS in contact with their ALLIANCE TOWER may extend beyond their NORMAL CONFIGURATION volume but may not exceed the FINALE CONFIGURATION maximum volume.
Unread 11-01-2010, 14:19
Matt C's Avatar
FRC #1468 (J-Birds)
Which of course is contradicted by the FINALE CONFIGURATION definition in 8.2, but I'm sure it will be amended in the first revision in Update #1. (There is an advantage to having a few thousand proof-readers checking your first release document)
Unread 11-01-2010, 14:20
AKA: Pinecone
They're mentioned in the same rule. I honestly don't think the GDC could overlook something like that. You don't have to be touching the tower in the last 20 seconds, you do before that.
Unread 11-01-2010, 14:24
MrForbes's Avatar
AKA: Jim
yup, read <G30> in it's entirety a few times....
Non-Cylindrical Bumpers? Tomasz Bania Technical Discussion 1 04-02-2008 15:53
Volume Accumulators rsegrest Rules/Strategy 4 24-01-2008 14:49
80 inch diameter? Pneumaticsman Technical Discussion 4 15-01-2008 08:54
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
Volume of tank + tube blindguyinanorg Pneumatics 8 18-02-2004 00:32
