Go to Post P.S. I'm not boring! - Matt Krass [more]
Unread 09-01-2010, 13:08
gitrdone gitrdone is offline
FRC #2994
gitrdone is an unknown quantity at this point
Question Couple of questions about the field and game
This is my first post
Was just wondering what the angle of the incline of the bumps in the arena are?
Just to clearify, the robot must climb up the tower itself, correct?
Thanks for any respones
Stephen
Team Captian
Team 2994
Kanata, Ontario
Unread 09-01-2010, 13:22
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Couple of questions about the field and game
I hate to be "that guy" but you really need to read the manual, Im sure it will answer all of your questions, and thus I won't answer it here. The information your looking for would be found in the arena documents and drawings section.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 09-01-2010, 13:24
-42-'s Avatar
-42- -42- is offline
Bangs His Head in Polyrythyms
AKA: *****
FRC #1388 (Eagle Robotics)
Team Role: CAD
-42- is an unknown quantity at this point
Send a message via AIM to -42-
http://www2.usfirst.org/2010comp/tem...he%20Arena.pdf
Unread 09-01-2010, 13:29
JJD JJD is offline
AKA: Jesse
FRC #2225 (R.U.S.T.)
JJD is an unknown quantity at this point
Yup. Please, just read the manual through once or twice. It'll answer many questions you have, answer questions you didn't know you had, and possibly even invoke some more questions (thats why you should read it twice )
If after reading it, you still have questions feel free to post again
-All the caffeine in the world can't fix this problem
Unread 09-01-2010, 13:50
Matthew2c4u's Avatar
Matthew2c4u Matthew2c4u is offline
AKA: Matt Baker
FRC #1622 (Spyder)
Team Role: Tactician
Matthew2c4u has a spectacular aura aboutMatthew2c4u has a spectacular aura about
Send a message via AIM to Matthew2c4u Send a message via MSN to Matthew2c4u
You can learn most of that from math, game designs and the animation but the short answer is 45 degrees and yes they have to climb themselves or hang off another robot who is above the plane.
This year is an "Outside" The box year.
Unread 09-01-2010, 13:54
Chrono101 Chrono101 is offline
FRC #1448
Chrono101 is an unknown quantity at this point
The manual doesn't specifically state the angle of inclination for the bumps. Using the field schematics (specifically GE-10047), I've calculated that the angle of inclination is about 45 degrees.
Unread 09-01-2010, 14:04
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
It should actually be a little shallower than that, as the ramps are extending from the base plates, and not from the floor, so subtract 1/4 or 1/2" from the 'rise' of the ramps. the ramp top is 12 " from the main floor surface, as far as I can tell.
(see 6.2.3)
Unread 09-01-2010, 14:06
AKA: Matt Baker
FRC #1622 (Spyder)
Rules show 45. But ill go check my math
FRC #1448
(see 6.2.3)
I used 12" as the height of the ramp from the floor.
Unread 09-01-2010, 14:18
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
i know. What height did you use from the floor to the bottom of the ramp? it's not 0.
Unread 09-01-2010, 14:41
FRC #1448
I read the schematic wrong. I've attached a screen shot of the side view of the bump. Since the dimensions for the sides of the triangle are 10.25" x 10.25", the angle of inclination from the point the bump stops going vertical is 45 degrees, although there is a transition up onto the bump structure from the floor itself.
Unread 09-01-2010, 14:47
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
that helps alot, and also shows that the 12" height /is/ in fact measured from the base plates and not the floor.
Unread 09-01-2010, 15:02
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
There is another picture missing from the picture posted before. There are plates that go onto that, that make it flush to the ground so there is no bump up onto the ramp it goes straight from the flat floor to the incline.
2012-Present Wave Robotics Team 2826
Unread 09-01-2010, 15:20
Eagle981 Eagle981 is offline
FRC #1013
Eagle981 is an unknown quantity at this point
Attachment 8247
If this picture is accurate the gap between the ground would be over 2 inches but I'm pretty sure this is wrong not to put down your information.
According to the competition manual there is approximately a 1/2 inch distance between the level playing field and the incline of the bump. Just thought I would put in my two cents since I was curious as well
Unread 09-01-2010, 15:39
Please see field drawing GE-10047 and you will see that there is no bump from the field to the incline of the bump!
Couple of questions? burningblane Rules/Strategy 3 10-01-2008 22:17
Couple questions Minitruck1506 General Forum 11 08-03-2006 01:34
couple of questions... archiver 2001 5 23-06-2002 22:48
A Couple Questions about Chairman's Award ben_whly Chairman's Award 4 26-01-2002 18:24
