Go to Post Blue Nitrile Tread is the best smelling wheel tread. #thingsyoufigureoutat2AM - Ginger Power [more]
Unread 09-01-2010, 14:08
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: 84 inch diameter vertical right cylindrical volume ?
it is slightly confusing, but the cylinder is defined using the robot's coordinate system (flips over with the robot), even thought the cylinder itself is called a 'vertical' right cylindrical volume.
(specifically <R10> During the MATCH, the ROBOT will assume one of two operating configurations. When in each configuration, the ROBOT shall fit within the limits shown below (note: these limits are defined in reference to the ROBOT, not the FIELD). (emphasis mine))
Non-Cylindrical Bumpers? Tomasz Bania Technical Discussion 1 04-02-2008 15:53
Volume Accumulators rsegrest Rules/Strategy 4 24-01-2008 14:49
80 inch diameter? Pneumaticsman Technical Discussion 4 15-01-2008 08:54
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
Volume of tank + tube blindguyinanorg Pneumatics 8 18-02-2004 00:32
