Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 09-01-2010, 15:15
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Cool Dimension of Bump
What is the base dimension of the bump in terms of length [trapezoid]
1/2(12+b2)h= area
What is b2?
Unread 09-01-2010, 15:19
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Dimension of Bump
Oh people, please read the manual, but the bump is 12" wide at the top, and approx. 32.5" wide at the bottom, creating a approx. 45 degree angle.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 09-01-2010, 15:20
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
I don't remember that actually being in the manual. Get game-specific drawing GE-10047 if you want the drawing (it is indeed 33.5 inches).
Unread 09-01-2010, 15:21
You might check out http://usfirst.org/roboticsprograms/....aspx?id=16097
Not only will it have the dimension you seek, it has all the field dimensions that you need to build a version for your team. Once you look at the drawings, of course.
Unread 09-01-2010, 15:23
5n1p3r's Avatar
IM 5n1p3r
AKA: Matthew
I just figured out the angle of is 45 degrees, therefor the base length is 36"
Unread 09-01-2010, 15:27
AKA: Scott
Correct, I was quoting the size of the support rib, which is shown in the drawing.
Unread 09-01-2010, 15:38
Alumnus
That doesn't seem to be right. Did you take into account the portion that is "vertical"? The drawing shows that the its profile is that of a hexagon. The trapezoid is raised up 2.1875 inches above the ground. The height of the actual trapezoid seems to be 10.25" (excluding the portion below it), with a specified angle in the drawing of 10.25, giving a total height of 12.4735 inches.
Unread 15-01-2010, 00:51
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
When I look at drawing GE-10047.pdf, the height of the rib is 12 7/16". When you add the 3/4" plywood on top that makes the height of the bump 13 3/16" without the carpet. Does this seem right? I thought the bump should have been much closer to 12".
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Trailer dimension contradictions? Stephanie.S Technical Discussion 0 14-01-2009 15:21
1/2" bump in field? Doug G Technical Discussion 8 30-01-2008 12:41
<G18> - Maximum dimension StevenB Rules/Strategy 2 09-01-2008 20:48
Line or Bump? Swathi General Forum 2 05-01-2008 16:08
