Go to Post The closest thing to "Senior Mentor" we have is "Team Grandma". :) - Alan Anderson [more]
Unread 09-01-2010, 15:25
turboweeee turboweeee is offline
FTC #3162
turboweeee is an unknown quantity at this point
Post What gets you 2 points
The one-page summary says a robot needs to be hanging to get 2-points, but the video showed one siting ontop of the platform. The manual just says above the plane. What's correct?
Unread 09-01-2010, 15:26
Re: What gets you 2 points
The Manual is correct, unless it is corrected by an official update.
Unread 09-01-2010, 15:36
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
Seeing as a plane is infinitesimally thin, I would say that by sitting on top of the platform, you ARE above the plane. It's a question that is worthy of Q&A in my opinion, though, just to make sure.
Unread 09-01-2010, 15:40
Section 7.2: ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED.
It's (presumably) above the plane and definitely in contact if it's on the platform. So the question would simply be, is being on top of the platform counted as being above the plane?
Unread 09-01-2010, 15:41
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
<G04> "b. Each ELEVATED ROBOT is awarded 2 points, or each SUSPENDED ROBOT is awarded 3 points."
7.2 Definitions: "ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED."
My guess is that a robot sitting on the PLATFORM is above the plane of the PLATFORM. So if it is in contact with the TOWER it scores 2 points. Ask Q&A to confirm.
(since 2004)
Unread 09-01-2010, 17:14
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Under the assumption that said surface is completely flat and is the plane, it would be, otherwise we have some problems with physics, because otherwise the implication is that the robot is physically intersecting the surface.
Unread 09-01-2010, 22:27
Ramiro_T's Avatar
Ramiro_T Ramiro_T is offline
Technical Specialist
AKA: Ramiro Trejo
no team (n/a)
Team Role: Student
Ramiro_T is an unknown quantity at this point
During the game animation, stop it as the camera goes over the tunnel and the bumps. You will see an additional bump right belop the large bump with the 45 degree slope. Then let the video play until that blue robot drives into the tunnel. The point of that scene is to illustrate possibilities on how to score 2 points. Either you hang from the bar, go on the platform, or just go into the tunnel.
Unread 09-01-2010, 22:29
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The game animation is not the manual and should not be used for purposes of rules questions.
Unread 09-01-2010, 22:30
The tunnel does not count under <G04> and the definition of "Elevated".
<G04> Scoring - ALLIANCE scores are determined by a combination of the number of BALLS SCORED in the ALLIANCE GOALS during the MATCH and the number or ROBOTS in the following states at the conclusion of the MATCH, where:
a. Each SCORED BALL is worth 1 point, and
Unread 10-01-2010, 23:50
shocker4256's Avatar
shocker4256 shocker4256 is offline
AKA: Luke Pukatch
FRC #0177 (Bobcat Robotics)
shocker4256 is an unknown quantity at this point
So really the question I think most teams have is, What is considered the plane of the platform and where does it start? Can a robot sitting on the platform touching a part of the tower be considered elevated?
Also I want to add one more question, Could a robot pick up another robot and make it touch the tower? Would this be considered elevated? I don't see any place in the manual where it says it isn't elevated as long as it is above the plane.
Unread 10-01-2010, 23:55
Happy Birthday! Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
It seems to me that the PLATFORM is part of the TOWER:
6.2.4 The TOWERS
A TOWER is located in the center of each BUMP. Each TOWER is composed of a base and a pipe superstructure. The PLATFORM is the horizontal surface of the base, and provides a solid surface to support ROBOTS during the game.
PLATFORM = part of base.
base = component of TOWER.
PLATFORM = component of TOWER.
Just sitting on the platform, you are contacting the tower, per 6.2.4. You don't need to touch the bar. You are ELEVATED just by sitting there.
Any disputes of this? This is the most logical conclusion and the one I'm going with unless the GDC says otherwise via Q&A or Team Update.
What Happens When Metal Gets Into A Jaguar (SMOKE!!!!) dwaynetrip3119 General Forum 19 13-04-2009 08:37
who gets the points? firstborn Rules/Strategy 11 13-01-2006 16:55
pic: YMTC: 150 points or 100 points? CD47-Bot Extra Discussion 4 25-03-2004 01:53
Ventures Points- What To Do With Them? Joe Matt CD Forum Support 9 17-12-2002 13:55
