Re: What gets you 2 points
Section 7.2: ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED.
It's (presumably) above the plane and definitely in contact if it's on the platform. So the question would simply be, is being on top of the platform counted as being above the plane? |
During the game animation, stop it as the camera goes over the tunnel and the bumps. You will see an additional bump right belop the large bump with the 45 degree slope. Then let the video play until that blue robot drives into the tunnel. The point of that scene is to illustrate possibilities on how to score 2 points. Either you hang from the bar, go on the platform, or just go into the tunnel.
So really the question I think most teams have is, What is considered the plane of the platform and where does it start? Can a robot sitting on the platform touching a part of the tower be considered elevated?
Also I want to add one more question, Could a robot pick up another robot and make it touch the tower? Would this be considered elevated? I don't see any place in the manual where it says it isn't elevated as long as it is above the plane. |
#7
It seems to me that the PLATFORM is part of the TOWER:
6.2.4 The TOWERS A TOWER is located in the center of each BUMP. Each TOWER is composed of a base and a pipe superstructure. The PLATFORM is the horizontal surface of the base, and provides a solid surface to support ROBOTS during the game. ***** PLATFORM = part of base. base = component of TOWER. PLATFORM = component of TOWER. Just sitting on the platform, you are contacting the tower, per 6.2.4. You don't need to touch the bar. You are ELEVATED just by sitting there. Any disputes of this? This is the most logical conclusion and the one I'm going with unless the GDC says otherwise via Q&A or Team Update. Last edited by Travis Hoffman : 10-01-2010 at 23:57. |
| What Happens When Metal Gets Into A Jaguar (SMOKE!!!!) | dwaynetrip3119 | General Forum | 19 | 13-04-2009 08:37 |
| who gets the points? | firstborn | Rules/Strategy | 11 | 13-01-2006 16:55 |
| pic: YMTC: 150 points or 100 points? | CD47-Bot | Extra Discussion | 4 | 25-03-2004 01:53 |
| Ventures Points- What To Do With Them? | Joe Matt | CD Forum Support | 9 | 17-12-2002 13:55 |
