Go to Post We're moving to metric, inch by inch. - Joe Ross [more]
Unread 09-01-2010, 18:32
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
G17 Algorithm
BALL Return Timing - BALLS must be returned to the FIELD within a specified period of time to prevent delaying the game according to the following algorithm:
Texpire = Tscore
• where T - [11 + (4 * n)]
expire
• T, is the match time, in seconds, assigned to each individual BALL, at which point the Field Management System automatically assigns a PENALTY if a BALL is not passed through the BALL RETURN COUNTER,
score
• n is the number of balls that have passed through either BALL COUNTER of the ALLIANCE, but not yet passed through the BALL RETURN COUNTER. is the remaining match time, in seconds, on the match timer when the ball enters the BALL COUNTER, and
If your alliance is in the possession of a ball with 15 seconds or less left, you have 0 seconds to place it on the ball return, thus incurring a penalty. At this point, it seems that your team should try putting balls in your opponents goal, giving them penalties. Is this a viable strategy?
Unread 09-01-2010, 18:37
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: G17 Algorithm
No you have until the clock reads 0 to get the ball back on the field. You are solving for the time on the clock, not the time you have to move the ball.
- Arizona North
Unread 09-01-2010, 18:38
Re: G17 Algorithm
Incorrect.
T expire (x) = T now – { 11 + (4 * # unexpired balls currently in Station) }
T expire is the time at which the penalty is applied.
So, you put a ball in at 15 seconds left. Texpire = Tnow-{11+4*unexpired)}
Tnow is 15. We will assume an empty alliance station (unexpired = 0).
Texpire = 15-(11+4*0)=15-11=4.
They have until the timer reads 4 seconds left to put the ball back out.
For reference, the DOGMA document on the FRC website will help understand the algorithm. It is at http://usfirst.org/uploadedFiles/Com...sets/DOGMA.pdf
Unread 09-01-2010, 19:22
Passion Passion is offline
Jim Zhou
FRC #2198
Passion has a spectacular aura aboutPassion has a spectacular aura aboutPassion has a spectacular aura about
Re: G17 Algorithm
Incorrect.
So the unexpired balls is any balls in the station prior to the incoming ball?
In this case, the unexpired balls would be 0, because you are assuming that there aren't any balls in the station until the ball rolls into the station.
Unread 09-01-2010, 19:28
Re: G17 Algorithm
Exactly.
Unread 11-01-2010, 10:30
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Re: G17 Algorithm
What happens if a ball is scored at 1 second? Is there some point were the system stops? I'm guessing that any ball scored after 11 seconds wouldn't need to be put back into play. Please don't show me any formulas, i'm just a dumb parent that can't figure this out.
Unread 11-01-2010, 10:43
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: G17 Algorithm
no. Once you get down to 11 seconds you would have until 0 secs to get the ball back... and once 0 seconds is hit, you cannot receive a penalty. Therefore, the ball doesn't have to be returned.
Unread 11-01-2010, 14:36
GaryVoshol's Avatar
Cogito ergo arbitro
Re: G17 Algorithm
That's a logical conclusion, but it should be verified with Q&A.
(since 2004)
Unread 11-01-2010, 20:31
karatekid's Avatar
karatekid karatekid is offline
AKA: Cole
karatekid has a spectacular aura aboutkaratekid has a spectacular aura aboutkaratekid has a spectacular aura about
Re: G17 Algorithm
Ok, but this is getting pretty annoying. It seems like there's about 5 threads all about G17. PLEASE look at other threads before starting a new one and add on to the other if it's related.
YOU JUST LOST THE GAME!
Possible Discrepency - G17 AlexD744 Rules/Strategy 14 10-01-2010 22:57
Update 4.3.4.3 <g17> Dominicano0519 Rules/Strategy 3 12-03-2006 12:01
AEC Algorithm cprogrammer Programming 4 03-10-2005 19:03
Panning algorithm jgannon Programming 6 08-03-2005 16:19
Warnock´s Algorithm sutto Computer Graphics 2 24-05-2004 14:05
