Go to Post I think this says it all... It's Fantasy FIRST on Chief Delphi. - Zach O [more]
  #31   Spotlight this post!
Unread 09-01-2010, 19:26
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: 9.3.4 Match Seeding Points
Originally Posted by StevenB View Post
I agree with MathKing and Lil' Lavery that a 6-team cooperative effort could be very fruitful. Let's try some numbers, ignoring the tower bonuses for the moment.
1) Suppose that in a "normal" round, the Red Alliance can score 8 points against the Blue defense, while the Blue Alliance can only score 3. Red gets 8 + 2*3 = 14 seeding points; Blue gets 8 seeding points.
2) In a second scenario, Red scores 8 times, 6 for Red, and twice for Blue. Blue scores 3, making the final score 6 to 5. Red gets 6 + 2*5 = 16; Blue gets 6.
3) Now suppose the alliances cooperate - this makes both sides far more productive. I'll suggest that Red can now score 12 balls, while Blue scores 4 (in Red's goal). Red gets 16 + 2*0 = 16 seeding points; Blue also gets 16 points.
Here's another proposition with respect to your third one.
Say that that the score is 8-8
Each alliance gets 8+8*2=24, which is 50% more. In every scenario in which there is an even numbered total score, it is always more beneficial to both teams to split the score evenly.
  #32   Spotlight this post!
Unread 09-01-2010, 19:32
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
I agree with this, with one corollary: I think most people are assuming that two teams, each playing defense on the other, will always score fewer points than two teams scoring in coopertition with no defense being played. I agree with this assumption for the most part.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
  #33   Spotlight this post!
Unread 09-01-2010, 19:34
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Originally Posted by Lil' Lavery View Post
However, I can guarantee you we will see it attempted at least once per regional event.
I think you will see it once or twice per regional, but probably only that. If there are 4 different basic scoring outcomes for an alliance {zero points, score points, score on both alliances and win, and tie} then there would be basically 5 different combinations {zero points v score points, zero points v score on both, score points v score points, score points v score on both, and tie v tie}. Let's say for the sake of argument, the Blue alliance is on the losing side of the match (except for a tie, of course). In that case, the Blue alliance will get the same number of seeding points as the winning alliance (not including penalties) - so therefore derives no advantage over the Red alliance in terms of moving up the ranking - in 2 cases. This also includes the tie situation. Therefore, it is in the best interest of the Red alliance to not only win, but insure that the Blue alliance also scores. This is true in 3 of the 5 combinations. So by a 3:2 ratio - it is in the best interest of an alliance to win and to have the losing alliance score as many points as possible. The best case is to win by as close a margin as possible, even if that means scoring for the opposing alliance.
Therefore, if the Blue Alliance recognizes that the Red Alliance's best strategy is to have a Med - High score for both alliances, and will score on the opposing alliances goal if necessary, and visa versa. You have the Nash Equilibrium as far as the game strategy is concerned. If you attempt to have collusion, and have a zero point v score high points scenario, and a team defects, by breaking this agreement (scoring on the opposing alliance to maximize their score, or by accident), then you will now have "Tit-for-Tat" and you could never have that agreement again, since everyone would assume you would cheat again, and would then defect from any agreement you would attempt to make – even if they initially agreed to it. (You might get forgiveness for the first time you “cheated”, but not twice!)
Best regards,
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
  #34   Spotlight this post!
Unread 09-01-2010, 19:43
Alumnus
Since right now we're purely theoretical. This setup could potentially generate higher scores (with respect to total points) than the shutout collusion.
Reasoning:
Given that the shutout collusion ideally has six robots scoring on one side, the bottleneck will likely be the return of balls to the field. If an arranged tie takes place, you can score in both sides and will therefore be able to generate higher output due to approximately double capacity to return balls to the field.
  #35   Spotlight this post!
Unread 09-01-2010, 19:53
StephLee's Avatar
AKA: Stephanie
Reasoning:
I definitely see your point. I do, however, see a higher incentive to "cheat" in this situation than in the collusion shutout, and a wider gap between the winner and loser if cheating does occur. Thus, I as a strategist would be less willing to try this strategy if I know or suspect that my opponent has the capability to outscore me.
  #36   Spotlight this post!
Unread 09-01-2010, 19:59
Matthew2c4u's Avatar
Matthew2c4u Matthew2c4u is offline
AKA: Matt Baker
FRC #1622 (Spyder)
Team Role: Tactician
Matthew2c4u has a spectacular aura aboutMatthew2c4u has a spectacular aura about
Send a message via AIM to Matthew2c4u Send a message via MSN to Matthew2c4u
So basically, if you can trust your opponent enough and you have enough skill to go for the tie its the most benefical for both teams
If have very little chance against a team its better to help them score
and if your ahead by more than 15 points you should be helping other team score.
Sounds like a plan.(Sarcasm)
This system is definatly unique, but its feasibilty is in question in my mind.
This year is an "Outside" The box year.
  #37   Spotlight this post!
Unread 09-01-2010, 20:01
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Originally Posted by Richard View Post
This seeding system appears to be an embodiment of the invention protected under US Patent 7507169.
The inventor? Dean Kamen.
I believe this patent is from 2003 where there were significant complaints of 'collusion' between opposing teams during seeding at many regionals. It will be interesting to see if this makes a comeback.
  #38   Spotlight this post!
Unread 09-01-2010, 20:03
SteveGPage's Avatar
AKA: Steve
Exactly. Zero Point v High Points OR Tie score collusions are extremely suspect in that the "cheater" has a strong motive to cheat and defect from the agreement. The upside is that they move up in the ranking on the 3 opposing teams, the downside is that they won't be trusted in one of these agreements again. Also - you would have to get all three members of the alliance to agree and not cheat individually, when all three of them may be thinking, those other three teams could be the difference between my team being in the top 8 or not.
  #39   Spotlight this post!
Unread 09-01-2010, 20:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
The game described in the patent is indeed Stack Attack (FRC 2003). Dean filed the patent application in 2004 and it was issued in 2009.
Richard Wallace
since 2003
  #40   Spotlight this post!
Unread 09-01-2010, 20:07
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Does anyone else (who's been in FIRST long enough to remember) have a very uneasy presence of the ghost of 2003?
Do a search on the word "collusion" to see the very heated arguments over what people did back in the day to seed better. I can't believe FIRST would want to invite that kind of ugliness back again
  #41   Spotlight this post!
Unread 09-01-2010, 20:09
Alumnus
That is very true. But then from an audience standpoint, a collusion shutout won't be very popular. It would be boring, and for those who don't know how seeding works (e.g. a spectator just walking in like somebody's parents), it will really confuse them. With respect to the audience, an intentional tie will be more entertaining, because you might not know if somebody made a mistake, cheated, or got a penalty, which would change the outcome of the match.
From a scouting perspective, that pretty much tells me almost nothing about the robost. Sure, I can see that it's scoring, but I can't see how well the driver reacts under the pressure of a defender. I can't see how well the bot in the middle of the field is at tracking down balls and avoiding the other or causing the other to lose a ball. I can't see if the defensive bot is good at its job. The only thing it really tells me is whether the human player with the trident is fast or not.
Sure, the intentional tie doesn't really either, but I think it'd be a lot less boring to watch. Not to mention then I can at least see both alliances' human players in action.
  #42   Spotlight this post!
Unread 09-01-2010, 20:11
StephLee's Avatar
AKA: Stephanie
I wasn't around until two years after that, but I remember it being a topic of discussion even when I joined. I don't think I'd like to see it first hand.
I am hesitant to agree that an intentional tie would be likely to entertain the audience either, especially if the audience is expecting competition and realizes halfway through a match that the teams are simply scoring in their own goals with no real intention to actually compete against one another.
  #43   Spotlight this post!
Unread 09-01-2010, 20:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I agree with some of the concepts in your post, but you're missing an important point. In this case it does indeed not result in any notable advantage for the red alliance to gain points in the standings over the blue alliance, but if they end up getting more seeding points than a "standard match," they get a net bonus when compared to the other teams in the field (not playing on either alliance).
Say team X is on the red alliance and team Y isn't playing. Team Y is done playing matches and has 100 seeding points. Team X has one match remaining and has 80 seeding points. In a competitive match, the red alliance might win 6-5 and get 16 seeding points (not enough for Team X to catch Team Y). In a colluded match, the red alliance might win 21-0, and Team X could pass Team Y. Or they could attempt to tie 7-7 and earn 21 seeding points for both alliances, in which case Team X passes Team Y as well.
  #44   Spotlight this post!
Unread 09-01-2010, 20:15
SteveGPage's Avatar
AKA: Steve
The big risk however to an "intentional" tie agreement (and I still see that there is a lot of risk that someone would also cheat) is that due to the shear magnitude of penalties that are possible, you would have to have an intentional tie, with absolutely no penalties. How many times have we seen matches that appeared to go one way, to only after the penalties were assessed, the match went to the other alliance. Many of the penalties - case in point "Overdrive" - were not obvious to the team/alliance at the time because they couldn't tell that had even violated a rule due to limited vision what the robot was doing on the far side of the track.
  #45   Spotlight this post!
Unread 09-01-2010, 20:17
Alumnus
Note that I said more entertaining than a colluded shutout, which is a valid point. The reason for this is because you still don't know if one team will cheat at the end or of somebody will make a mistake or get a penalty be accident.
I'm well aware of this. However, I don't see many of the penalties this year being like <G22> and maybe <G35> from 2008. I'm fairly certain that the only one that might be like this not crossing the center line in autonomous.
Match Ranking Points Daniel Bathgate Rules/Strategy 3 06-01-2008 00:25
pic: QF match that set new record score = 220 points CD47-Bot Extra Discussion 3 29-03-2004 15:34
Seeding System Koci Rules/Strategy 23 25-03-2004 15:27
pic: YMTC: 150 points or 100 points? CD47-Bot Extra Discussion 4 25-03-2004 01:53
Seeding Calculations archiver 2000 50 23-06-2002 21:57
