Go to Post How about "The 2007 FIRST Robotics Competition International World Championship Event Of Atlanta Consisting Of Competition, Gracious Professionalism, Robots, And Geeky Fun"? Somehow I doubt it will catch on... - raymaniac [more]
Unread 09-01-2010, 17:05
Guopeter Guopeter is offline
AKA: Pie
FRC #0296 (Northern Knights)
Guopeter is just really niceGuopeter is just really niceGuopeter is just really niceGuopeter is just really nice
Robot Dimension Clarification
Happy New (FRC) Year everyone,
I have question regarding the robot dimension if anyone could clarify.
Is it allowed to have a robot that's not rectangle-shaped.
___ .........___
|...|_____|...|
|___________|
*the .......... are space fillers
I didn't see anything in the rules forbidding such design.
HOWEVER, robots are required to have its team number visible on the bumpers approximately 90 degrees apart.
This meas...no circular bots?
Am I wrong?
-Pete
Team 296
-Northern Knights 296
-Beaverworx 2609
Unread 09-01-2010, 17:39
Re: Robot Dimension Clarification
The limiting factor of shape seems to be that no bumper segment can be shorter than 6" (<R07-B>), and the entire frame perimeter must be protected by bumpers (<R07-A>).
Unread 09-01-2010, 17:49
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Yes, you can do this in a similar fashion as it was done last year (minus the whole trailer hitch thing). Since the frame perimeter can be determined by wrapping a string around your robot, the "concave" part will not be counted as a part of the perimeter. As long as the short parts in fronts have legal bumper you'll be fine.
Unread 09-01-2010, 17:53
Not under the definition of "frame perimeter" and <R07-A>.
Originally Posted by Section 8.2
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME
PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
Unread 09-01-2010, 18:25
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
<R07-N> has a diagram showing the bumper can't go over the gap. Also the frame perimeter definition says "outermost verticies" That wouldn't count the gap, right?
ATannahill ATannahill is offline
AKA: Alex Tannahill
I see no rule against it but you will have to have bumbers 100% around the edge of the robot.
- Arizona North
Unread 09-01-2010, 18:30
Look at the note with the definition. It says that the way you check is to wrap a string around the frame in the bumper zone. That's your Frame Perimeter. This includes gaps.
We had this debate last year over diagrams. They are meant to illustrate the rules that reference them, not be the rules. (Last year's Q&A)
In this case, Figure 8-3 is not referenced by <R07-N>; it's referenced by <R07-M>, which clearly states that the bumper must be supported by the frame/structure of the robot. Any bumper over a gap is not legal, and the robot will not be allowed to compete. The gap is included in the frame perimeter.
Unread 09-01-2010, 18:36
AKA: Ian Thompson
Exactly that though: string around the Bumper zone. It says nothing about pulling the string back for any gaps, leaving the frame perimeter as the outside edges of the robot. Since <R07-M> says it must be backed by the robot itself, it leaves the gap out
Unread 09-01-2010, 18:42
The string itself is the frame perimeter.
Therefore, any gap in the robot frame in the bumper zone must have a structural support running over it to support the bumper.
Unread 09-01-2010, 18:45
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Assuming that design would be a well for the ball to "settle in" do remember that bumpers must be between 10" and 16" of the ground. This allows enough room for your "ball well" to go beneath your bumpers.
Again assuming that well was for herding balls
-Mcgurky
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 09-01-2010, 18:56
AKA: Pie
-Mcgurky
Yes. I am fully aware of the bumper height.
The non-rectangular chassis design is for something else.
-Beaverworx 2609
Unread 09-01-2010, 20:40
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
This doesn't seem to be allowed even if the bumpers go completely around the edge of the concave portion. The wording is subtle but it doesn't seem like any concave configurations will be allowed at all by way of:
<R07>A: Bumpers must cover the entire FRAME PERIMETER
FRAME PERIMETER is determined using the string-wrap method (thus spanning the gap)
<R07>M: Bumpers can't span gaps where there is no physical frame on which to attach
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 09-01-2010, 20:55
DonRotolo's Avatar
Back to humble
FRC #0832
If the robot has such a gap, it can't be behind the bumpers. So if you want the gap in the 0" to 9.99 inch above the floor area, should be OK. At bumper height the frame can't have the gap in my interpretation.
This is my opinion, which is worthless for any FRC competition.
Unread 09-01-2010, 20:57
And it's even more worthless if the ball goes more than 3" into the frame. (<G46> specifies 1 penalty for such action.)
But yes, no gaps at bumper height is my interpretation too.
Unread 09-01-2010, 21:24
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
now can you use guiding bars to guide the ball to the middle of the bot beneath the bumpers, of course using only 3 inches of the ball.
Dimension of Bump 5n1p3r Rules/Strategy 7 15-01-2010 00:51
Trailer dimension contradictions? Stephanie.S Technical Discussion 0 14-01-2009 15:21
Question on the Dimension of the Robot ScottX General Forum 4 03-01-2009 23:42
<G18> - Maximum dimension StevenB Rules/Strategy 2 09-01-2008 20:48
Minor Goal Dimension Todd Lawless OCCRA 1 21-10-2002 22:28
