Go to Post A robot that does 60% of the tasks 100% of the time is better than a robot that does 100% of the tasks 60% of the time. - artdutra04 [more]
Unread 09-01-2010, 20:42
MarcusF MarcusF is offline
#0157 (Aztechs)
MarcusF is an unknown quantity at this point
Send a message via AIM to MarcusF
R19
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside the FRAME PERIMETER below the level of the BUMPER ZONE.
I'm a bit confused sounds like some people may be as well.
It can not go below more than 3", but it could go above the bumper zone more than 3"? Am I reading this wrong?
Unread 09-01-2010, 20:45
Re: R19
Try <G46>:
<G46> BALL Penetration Restriction – The BALL must not extend more than 3 inches inside the FRAME PERIMETER as defined in Rule <R19>. Violation: PENALTY for a basic infraction, plus a YELLOW CARD if no immediate attempt to remedy.
Unread 09-01-2010, 20:49
Rachel Gebhart Rachel Gebhart is offline
FRC #0492 (Titan Robotics)
Rachel Gebhart is an unknown quantity at this point
Re: R19
I think that it is legal for the ball to extend more than 3" inside of the robot above the bumper perimeter, however, I think this would count as possession since the ball probably would not be touching the ground anymore.
Ryan Simpson's Avatar
Ryan Simpson Ryan Simpson is offline
FRC #1676 (Pascack Pi-oneers)
Ryan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant futureRyan Simpson has a brilliant future
Re: R19
I believe that the intent of this rule is to prevent teams from engulfing balls under their robots in order to herd them. That would make defense impossible for the opposing alliance.
Hope that cleared it up a bit.
Unread 09-01-2010, 20:51
kbaker159 kbaker159 is offline
AKA: Kevin
FRC #0159 (Alpine Robotics)
kbaker159 is a jewel in the roughkbaker159 is a jewel in the roughkbaker159 is a jewel in the rough
Re: R19
I know Rules are the most important, but the comment after <G46> is a little confusing to me.
"A BALL trapped under a ROBOT, intentionally or unintentionally, will be considered POSSESSED until it is dislodged from the ROBOT. Teams are encouraged to design and drive with this in mind."
Does that mean the balls are able/allowed to go farther under than the 3 inches so long as they are underneath the robot rather than in/on it? I wouldn't think this would be allowed based on <G46> and <R19>, clarification would be appreciated.
Kevin Baker - Rensselaer Polytechnic Institute '13
Alumni, College Student, Mentor
FRC 159 - Alpine Robotics
http://www.alpinerobotics.com
159
GO ALPINE!!
Unread 09-01-2010, 20:54
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: R19
While under the robot the ball may not go further than 3 inches past the frame perimeter of the robot. The ball may not be possessed by a robot while not touching the ground.
- Arizona North
Re: R19
Nope. Remember, <G46> is a penalty. Not only that, you can't control another ball (penalty, <G43>).
Are they able to go under? Most likely. But you really don't want to be stuck on one all match. Design so the balls don't go under, and so that you can get them out quickly if they do.
Unread 09-01-2010, 20:55
Chris is me's Avatar
AKA: Pinecone
Re: R19
9 inch balls, 10-16 inch bumper perimeter, double penalty.
You only get 3 inches of grip on the ball. It makes this game hard...
Unread 09-01-2010, 21:04
dmoody92 dmoody92 is offline
FRC #3015
dmoody92 is a jewel in the roughdmoody92 is a jewel in the roughdmoody92 is a jewel in the roughdmoody92 is a jewel in the rough
Re: R19
Well, I believe you can get a little more than 3 because it says FRAME PERIMETER. Also, you can extend your robot's grasping mechanism to the limits of your bumper boundary.
Unread 09-01-2010, 21:09
Re: R19
If it's an active one, you just violated <G45>. If it's there for more than 2 seconds, you just violated <G30>. And if the ball goes more than 3 inches inside the frame, <G46> violation.
Just some design considerations that you'll want to take into account when designing said grasping mechanism.
Unread 09-01-2010, 21:15
FRC #3015
Re: R19
I believe you are allowed to extend a mechanism to the limit of your bumpers BELOW the bumpers which what I meant. Giving you 3" plus the width of your bumpers.
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Re: R19
It seems one has only violated <G45> if they have grabbed it above the BUMPER ZONE or lifted it off the carpet. I would think that as long as you keep it under 2 seconds and keep it on the ground, you could have up to six inches of interaction.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 09-01-2010, 21:49
Re: R19
True. OK. So <G30-A> is the only rule that would really apply. That's going to be tricky to do.
