Go to Post Coming soon to an Earth near you; an Australian team (or 2). Stay tuned. - Elgin Clock [more]
Unread 09-01-2010, 21:30
JasonStern JasonStern is offline
FRC #1123 (AIM Robotics)
JasonStern is on a distinguished road
"Heading" balls?
The following rules apply to robot interaction with the balls:
<G44> BALL CARRYING – ROBOTS may not CARRY BALLS.
<G45> Active BALL control - ROBOTS may not control BALL direction with active MECHANISMS above the BUMPER ZONE.
<G46> BALL Penetration Restriction – The BALL must not extend more than 3 inches inside the FRAME PERIMETER as defined in Rule <R19>.
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside the FRAME PERIMETER below the level of the BUMPER ZONE.
Do I read this correctly to mean we can "head" balls in the air if we don't possess or carry them? Does this also mean we can control the ball direction if the ball falls within our bumper zone from above as long a) the active control mechanism falls within the bumper zone and b) the ball never falls below the bumper zone?
Thanks!
Jason
Que será será
Unread 09-01-2010, 21:34
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
Re: "Heading" balls?
According to G45, the restriction on above-the-bumper active mechanisms, it would seem that a device to 'head' balls by hitting them back up would be against the rules. I believe that the 'bumper zone' it is referring to here is the area between and 10" and 16" off the ground, not the area exclusively above the bumpers, and thus G45 applies to above the whole robot.
Edit: Didn't read the original post too well. If the active mechanism is within/below the bumper zone, heading the ball might work. Back to the rules.
Unread 09-01-2010, 21:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm going to agree with DMetalKong's interpretation of <G45> and say you cannot use an active mechanism to interact with the balls above 16" from the ground (top of the bumper zone). However, a passive "head" with a frame of the robot would probably be acceptable, though very hard to do consistently or in a controlled fashion.
Unread 09-01-2010, 21:44
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
I cannot find a definition of "active". If it is simply any moving piece, then we should be able to have a stationary ramp or something on the robot which the ball can roll down so long as the track is stationary. If "active" means any part put there solely for the purpose of directing a ball somewhere, then this strategy is not legal. Thoughts?
Unread 09-01-2010, 21:45
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
So then could you put an active mechanism in the bumper zone(10 to 16 in.) without violating G45? The mechanism wouldn't be above the bumper zone, so technically. . .
Unread 09-01-2010, 21:56
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
"When reading these rules, please use technical common sense (engineering thinking) rather than “lawyering” the interpretation and splitting hairs over the precise wording in an attempt to find loopholes."
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 09-01-2010, 21:57
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
An actuated mechanism used to "head" the balls would very likely be a violation of G45.
However, I haven't spotted anything yet that would restrict heading with an inactive mechanism. It seems like a plausable way to deflect deposited balls back to your half of the field.
Unread 09-01-2010, 21:58
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Your bumpers are in the bumper zone and cannot be articulated.
Unread 09-01-2010, 22:00
AKA: Pierce Jensen
Also, what would the definition of carrying be? The rules aren't very clear. They state:
CARRYING: POSSESSING a BALL that is not in contact with the FIELD
POSSESSION: Controlling the position and movement of a BALL. A BALL shall be considered in POSSESSION if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the BALL remains in approximately the same position relative to the ROBOT.
So, how long would the ball have to be on the robot before it would be carrying?
Theoretically, if a ball falls on you while you are moving, and it stays on top of you, that would be carrying.
In response, the bumpers would close to the bottom of the zone so that the active mechanism could be closer to the top.
Unread 09-01-2010, 22:03
DMetalKong's Avatar
AKA: David K.
Yes, that would be carrying. It makes it very important to have a sloped top to your robot so that balls cannot stay up there.
Unread 09-01-2010, 22:32
AKA: Pierce Jensen
But how long could the ball stay on the robot while stationary before it becomes carrying?
Unread 09-01-2010, 22:37
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
I'd guess it's up to the judges. Your best bet is to move your robot so that it is no longer carrying the ball, just in case (ex. if the ball drops on to your robot and is on a ledge, move your robot so the ball moves off) .
FRC - Team 1885 - Programmer.
Unread 09-01-2010, 22:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The moment you're in possession of it.
Unread 09-01-2010, 22:41
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
But you are allowed to be in possession of a ball just as long as the ball is moving relative to where your robot is
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 09-01-2010, 22:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Yes, but if you're in possession of a ball while it's not touching the ground, it's carrying.
Originally Posted by Section 7, Definitions
CARRYING: POSSESSING a BALL that is not in contact with the FIELD.
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
