Go to Post If it is good enough for Paul and JVN it's good enough for me. - Vikesrock [more]
Unread 09-01-2010, 21:58
ssa3512 ssa3512 is offline
AKA: Steve
FRC #2537 (RAID)
ssa3512 is an unknown quantity at this point
Hanging robots and <G31>
<G31> BALL RETURN and RETURN BARS Protection - ROBOTS may not contact the BALL RETURN or the RETURN BARS (black tape). Violation: PENALTY for inadvertent contact; plus a RED CARD for obviously intentional contact or damaging contact.
If I am reading this right, this restricts the robots from hanging from three of the four sides of the tower, and effectively to only the midfield side of the tower as I see it practically impossible for a robot to balance on one of the bumps and then grab the side of the tower. This in turn essentially limits your team to ONE robot hanging from the tower (ELEVATED), meaning if the other two robots are going to score points from being off the playing field, they would have to either sit on the tower platform or be hanging from another robot (SUSPENDED) for three points.
What are some of your opinions on this rule, and my assumption that only one bar is viable for elevating your robot.
Unread 09-01-2010, 22:02
Re: Hanging robots and <G31>
Look below the ball return in the official drawings. There's another bar there, below the ball return. If you can avoid hitting ball return elements while hanging on that, you can hang on any side of the tower.
As for not being able to hang on the sides, I can think of two robots that would be able to do that right off the top of my head, if they're still running: the 60/254 collaborative twins. They wouldn't balance on the bump, either.
(Now that I've said this, watch those designs be copied all over the place...)
Unread 09-01-2010, 22:07
SamMullen SamMullen is offline
Team Alumni
FRC #0360 (Revolution)
SamMullen is a jewel in the roughSamMullen is a jewel in the roughSamMullen is a jewel in the rough
Look at page 8 of the "arena section" in the game manual. It shows the ball return as being above the top of the tower, and no parts of the tower have black tape, so I think you can safely latch onto all four sides.
Unread 09-01-2010, 22:12
AKA: Steve
FRC #2537 (RAID)
If you look at section "6.2.4 The TOWERS" of the manual, and the associated picture of the ball return attaching to the towers you see the following
The TOWER is designed to support the weight of several ROBOTS. The RETURN BARS are the two horizontal bars at the top of the rear of the TOWER (the side nearest the ALLIANCE WALL). The RETURN BARS support the lower end of the BALL RETURN and are covered in black tape.
This implies that both the upper and lower bar are "no-touch" areas, because they are both covered in black tape.
Unread 09-01-2010, 22:21
Good point. The side bar comment stands, though.
Unread 09-01-2010, 22:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Agreed on the side bar hanging. There's numerous examples of side hanging robots from 2004. Take your pick of implementations.
Unread 09-01-2010, 22:44
AKA: Steve
FRC #2537 (RAID)
... I can think of two robots that would be able to do that right off the top of my head, if they're still running: the 60/254 collaborative twins. They wouldn't balance on the bump, either.
Which previous year involved hanging? The years I participated as a student were '05 (Triple Play) and '06 (Aim High) in which there was no hanging.
I don't suppose you have a picture or care to explain how this mechanism would grab the side bar without balancing on the bump.
edit: thanks Kevin, I will try to find some pics from 2004 as well as looking at the game.
Unread 09-01-2010, 22:45
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
2000 and 2004. Take a plunge through CDMedia for pictures.
Unread 09-01-2010, 22:46
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
I think '04 (Raising the Bar) was the last hanging game.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 09-01-2010, 22:57
AKA: Steve
FRC #2537 (RAID)
I found this image of team 60's robot from 2004, and unless I am looking at it wrong, the robot would have to be facing the bar to attach to it, and according to the comments the hook starts attached to their ball grabber with velcro and the ball grabber is in line with the wheel base. Also, the tower does not extend past the base of the hump, so that robot would have to be sitting on the bump, facing the bar to attach to it, or am I completely wrong here?
edit: theoretically if the arm was on the extreme left or right of the bot, and the hook was positioned perpendicular to the arm, you could drive OVER the bump with the arm extended and the hook would snag the bar as you drove by.
Unread 09-01-2010, 23:02
You're off. They'd go flying past the bar at close range with their gripper open and their hook pole out. Next thing you know, their arm is folded and they're climbing a cable.
Here's a link to a shot of starting configuration. It's the twin, 254, but it gets the point across.
http://www.chiefdelphi.com/media/photos/18193
It was a sight to see...
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
the question i think youre asking is if you can hang on the cube shaped "tower" and the rule you have posted it for the return track which is the part above that the ball follows to get to the "tower and u cannot hang on that track at anytime during the match
Unread 09-01-2010, 23:21
http://www.chiefdelphi.com/media/photos/17238
There's 57's. No problems lifting from the side,save that the window lift was a little slower than might have been optimal.
Unread 10-01-2010, 16:00
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
frank.pendzich is an unknown quantity at this point
We're thinking about hanging off the virticle support posts on the tower. Our question is... Are the towers secured so they won't fall over with 130lb robot clamped on to one of it's verticle posts?
Unread 10-01-2010, 16:04
Mr.P
AKA: Mr. P
A student just asked if the rules prevented us from shooting a grappling hook over the top of the tower and pulling us up with a cable.
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
4 robots hanging ECarlson Regional Competitions 3 08-03-2004 00:27
Robots Hanging from the Floor Todd Derbyshire Rules/Strategy 16 13-01-2004 14:10
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Starting position and hanging clarification Don Wright Rules/Strategy 2 10-01-2004 14:21
