Go to Post So does this mean we can use the FP as bumpers? :D - Peter Matteson [more]
Unread 01-09-2010, 10:46 PM
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Hanging robots and <G31>
Originally Posted by ssa3512 View Post
Which previous year involved hanging? The years I participated as a student were '05 (Triple Play) and '06 (Aim High) in which there was no hanging.
I don't suppose you have a picture or care to explain how this mechanism would grab the side bar without balancing on the bump.
I think '04 (Raising the Bar) was the last hanging game.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 01-09-2010, 10:57 PM
ssa3512 ssa3512 is offline
AKA: Steve
FRC #2537 (RAID)
ssa3512 is an unknown quantity at this point
I found this image of team 60's robot from 2004, and unless I am looking at it wrong, the robot would have to be facing the bar to attach to it, and according to the comments the hook starts attached to their ball grabber with velcro and the ball grabber is in line with the wheel base. Also, the tower does not extend past the base of the hump, so that robot would have to be sitting on the bump, facing the bar to attach to it, or am I completely wrong here?
edit: theoretically if the arm was on the extreme left or right of the bot, and the hook was positioned perpendicular to the arm, you could drive OVER the bump with the arm extended and the hook would snag the bar as you drove by.
Unread 01-09-2010, 11:02 PM
EricH EricH is online now
You're off. They'd go flying past the bar at close range with their gripper open and their hook pole out. Next thing you know, their arm is folded and they're climbing a cable.
Here's a link to a shot of starting configuration. It's the twin, 254, but it gets the point across.
http://www.chiefdelphi.com/media/photos/18193
It was a sight to see...
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
the question i think youre asking is if you can hang on the cube shaped "tower" and the rule you have posted it for the return track which is the part above that the ball follows to get to the "tower and u cannot hang on that track at anytime during the match
Unread 01-09-2010, 11:21 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
http://www.chiefdelphi.com/media/photos/17238
There's 57's. No problems lifting from the side,save that the window lift was a little slower than might have been optimal.
Unread 01-10-2010, 04:00 PM
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
frank.pendzich is an unknown quantity at this point
We're thinking about hanging off the virticle support posts on the tower. Our question is... Are the towers secured so they won't fall over with 130lb robot clamped on to one of it's verticle posts?
Unread 01-10-2010, 04:04 PM
Mr.P
AKA: Mr. P
A student just asked if the rules prevented us from shooting a grappling hook over the top of the tower and pulling us up with a cable.
Unread 01-10-2010, 04:23 PM
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
There may be some other rules as well, but be careful of the size restriction. If you shoot it too high, or you miss, will you still be in a legal size configuration?
Also if you miss, can you get it back and try again?
Specifically you'll also want to read all the entanglement rules. It's not a chance I would personally take.
as far as hanging off the posts, some robots hanging from the top bar will be putting more torque on it than something holding onto the vertical posts.
also see this pic posted by someone else: http://www.chiefdelphi.com/forums/at...2&d=1263155312
Unread 01-10-2010, 05:45 PM
ATannahill ATannahill is offline
AKA: Alex Tannahill
Teach by example, read the rules. Also, you might want to put that in the form of a question if you want an answer.
- Arizona North
Unread 01-10-2010, 07:21 PM
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
the max height you can extend to is 90" and the bar is at 7' i.e. 84", so unless you can get it to fire between a 6" window while staying within the 84" cylinder during the final period sure... but there are far simpler solutions.
making sure your team has a full understanding of the rules while designing is very important.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 01-10-2010, 08:21 PM
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I think a robot in full trim should be able to hang off of one of the vertical support posts. I'd imagine, that the tower and it's mounting system was designed with a safe working load of about 900lbs or more. (900 lbs being derived from 6 robots hanging from the tower in some strange crazy illegal instance) The only thing you may experience while hanging is some slight warping of the bar, maybe a half inch to an inch at most.
Unread 01-10-2010, 08:29 PM
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
If you're all just discussing hanging and nothing else ignore this comment, otherwise you might recall that you can be on top of the tunnel (the platform that connects to the flat area of the bumps and is inside the tower). You can still get the 2 points but you'll need to fit in there. If you're having problems with hanging try resting on the platform and having other robots ramp on top of you for the 3 point bonuses.
If i have the interpretation wrong, please tell me.
The system is down.
Rockford Robotics 2039: Think outside the bots.
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 03-23-2004 01:42 AM
4 robots hanging ECarlson Regional Competitions 3 03-08-2004 12:27 AM
Robots Hanging from the Floor Todd Derbyshire Rules/Strategy 16 01-13-2004 02:10 PM
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 01-12-2004 07:14 PM
Starting position and hanging clarification Don Wright Rules/Strategy 2 01-10-2004 02:21 PM
