Go to Post You don't need to be on a team to be involved with FIRST. - Koko Ed [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 09-01-2010, 22:10
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Re: What do you think will be important this year?
Originally Posted by EricH
Hanging will be important, especially the ability to hang with another robot or two hanging from you.
If you ask me, having a handle, or some other convenient way for your comrades to hang onto your robot will be almost as important as the ability to hang in general. Being easy to grab and hang from will be a great advantage for an alliance.
Originally Posted by vance
Swinging? That's the third way to travel from one zone to the next.
Seems like it'd be slow and slightly dangerous (a fall might leave a big mark). Also, if I understand <G44> [BALL CARRYING – ROBOTS may not CARRY BALLS. Violation: 2 PENALTIES for each CARRIED BALL.] you wouldn't be able to bring any balls with you, so I'm not sure what the advantage of that would be as opposed to just trying to make it over the walls.
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 09-01-2010, 22:13
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Originally Posted by Lil' Lavery View Post
Wanna put money on that?
I think a tunnel-dependent robot will be easily shut down. If the opposing alliance's star robot is tunnel-dependent, then your alliance can just take your weakest robot and stick it in a tunnel.
Also, I think pushing in the tunnel will be difficult with the high-up bumper positions. The force of pushing will be acting on your robot horizontally, and most likely above your robot's centre of gravity. So your robot will tend to lift the side it is pushing with, and may very well flip.
Unread 09-01-2010, 22:27
SamMullen SamMullen is offline
Team Alumni
FRC #0360 (Revolution)
SamMullen is a jewel in the roughSamMullen is a jewel in the roughSamMullen is a jewel in the rough
On one hand, herding a ball in any controlled manner would be very hard to do if you are going over the bump. On the other, going under means having to fight the 36inx18in space of the tunnel (29inx18in after you've factored out bumpers on the sides).
vance's Avatar
vance vance is offline
AKA: Steve Inza
FRC #1058 (PVC Pirates)
vance will become famous soon enoughvance will become famous soon enough
The advantage is that unless another robot is also swinging, you cannot be blocked. You can be pinned or completely blocked in the tunnel, and you can be blocked or flipped going over the bumps. Of course you can't take a ball with you, but the only way to reliably travel zone-to-zone with a ball is through the tunnel anyway.
Unread 09-01-2010, 22:35
Ramiro_T's Avatar
Ramiro_T Ramiro_T is offline
Technical Specialist
AKA: Ramiro Trejo
no team (n/a)
Team Role: Student
Ramiro_T is an unknown quantity at this point
Don't forget about defense. You can stay in your starting zone and block the opposing alliance. And, you can block opposing alliance robots from traversing the tunnels and bumps in the center field to buy time. Then, when it comes to the finale, hanging is key earn some extra points at the end of the match. I mean, scoring the soccer balls is 1 point each. At the minimum, you'll probably be able to score 2-3 balls, given the circumstance. So, defense, as much as offense, and hanging will be a key role in this year's game.
Unread 09-01-2010, 22:38
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
Sorry to burst your bubbles but how are you going to swing from a bar that his higher than the 60 in height limit? To swing from it you would have to climb up the bump and if your doing that you might as well just go over the bump instead of wasting time to swing ....
2012-2016 Wave Robotics Team 2826
Unread 09-01-2010, 22:46
Chris is me's Avatar
AKA: Pinecone
I think tunnels will at least be an option for many teams, and a preferred one to the risky bumps for many. Not necessarily mandatory but they'll be used.
Balls also roll through sometimes.
Unread 09-01-2010, 22:48
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Vision / camera systems may be critical: We've started wondering (and won't know until we either build a Bump or CAD out the dimensions) if soccer balls will be easily visible across in the far zones because of the Bumps. If not, the ability for a robot to "see" will be critical, both on offense and defense.
"It's NOT Just A Robot Thing!"
Unread 09-01-2010, 22:49
Touch the tower. You can adopt Finale configuration any time you are touching the tower under <G30-C>.
Of course, if I was a ref, I might call an <S01> violation if you were swinging, depending on the manner of swinging. Definitely if a tower came down.
Unread 09-01-2010, 22:52
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Ability to play in any field zone will be a big factor for a number of teams, I think.
Ability to pass/receive passes will be something to watch for, as will be ability to defend the tunnels.
I doubt hanging will be that important within game play because a team that can score effectively and get the balls back out will be able to make up those points quickly. Personally I still want to hang, but more for political reasons within the regional, being able to hang well and have other robots hang from you can be something that will help set you apart from the rest of the competition.
Also on that note I think were going to see another competition where the human player will be a big part of things. The coralers won't need to do much, but they can ruin things if they're not paying attention to what's going on, but as we saw in the kickoff demonstrations with Dean, Woodie, and Lavery the trident holder, the more important of the positions, needs to work fast and avoid getting the ball stuck in the trident, from pushing it in to hard, and getting it stuck on the track, by spreading the track and having it close in on the ball.
Originally Posted by Don Rotolo View Post
The tunnels will be insignificant. Hanging from the tower will be common, until teams realize they can't defend during that time. Being able to move balls accurately is key.
Don I think there is some truth to what your saying because robots could become easily blocked if only able to move through the tunnel, but teams that can go through the tunnel will be able to move much faster than those who can only go over the ramp, if the tunnel isn't blocked. In my opinion the teams your going to see trying to move from zone to zone will try and go through the tunnel first, but have the capability to go over the ramps. Also I think a trend will start to develop where you'll see teams that don't hang during the endgame will be these bots that can go through the tunnel.
Unread 09-01-2010, 23:01
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Neither the tunnel or bump will be an effective mode of traveling from one zone to another. How do we move from zone to zone? You don't, at least, once you get your robot where you want it - you keep it there, and let your mechanisms do the scoring for you. One robot moves balls from the midzone to the alliance zone, and a second moves balls of the alliance zone to the goal. It's that simple.
Why you would need extra robots in a zone is, currently, beyond me.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 09-01-2010, 23:03
AKA: Pinecone
I'm wondering how these teams plan to shrink back to standard configuration before letting go. That's also rather important.
Unread 09-01-2010, 23:11
jamie_1930's Avatar
Team Role: Student
It all depends on how each teams strategy plays out in my opinion it would be best to stay in your area and be able to score effectively from there, but it's one of those things where you want the option to be able to travel from zone to zone.
Unread 09-01-2010, 23:13
RMiller RMiller is offline
Taking a Year Off
AKA: Ryan Miller
RMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really nice
For a robot in the opposing alliance's zone, getting back to the middle section might be important, depending on their goal.
Also, if there is only one robot working a zone, it might be quite easy to block balls from being passed from one zone to another.
2002-2004: 967 Mean Machine
2006-2008: 1816 Green Machine
2008-2010: 2739 Bucket of Bolts (BOB)
Unread 10-01-2010, 13:08
lemon1324's Avatar
lemon1324 lemon1324 is offline
AKA: Arul S
FRC #2473 (CHS Robotics)
lemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of light
As the balls are reintroduced at midfield, it could be advantageous to bring the third robot from the opponent's end to midfield. That would give you an edge in gaining possession of reintroduced balls.
"I reject your reality and substitute my own"
[IMG] code is Off
What do you think the AVA topic will be this year? Kevin Thorp 3D Animation and Competition 14 14-01-2008 17:31
What do you think will happen....? slickguy2007 General Forum 7 29-01-2007 18:39
what do you think high score will be nuggetsyl General Forum 13 03-04-2006 14:03
What do you think this year's competition will be NAMED? Elgin Clock General Forum 18 10-01-2004 19:35
Do you think this years game will be... Brian Savitt General Forum 26 09-12-2001 22:43
