Go to Post I clicked on "agree to terms" ........ crash. I think I killed the server. ;) - rees2001 [more]
Unread 09-01-2010, 19:27
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Robot Classifications
In the past we have had shooters, herders, dumpers, lappers, arms, cappers, and ramp bots.
So the question is: What will be the major classes of robots this year?
I think all the restrictions will actually produce a lot of varied ideas to attack the challenge.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 09-01-2010, 19:30
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Robot Classifications
I think there will be 4 major design types this year...
#1. kickers
#2. Goalies
#3. multi hangers
#4. Multi taskers...
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 09-01-2010, 19:38
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
As broad classifications, every robot should fit in to one of these:
Front Field/Offense
Mid Field/Supply Line
Back Field/Defense
All Around/Some combination of the above.
I see each section of the field requiring a slightly different play style. No matter what, a robot will have to start in one of these and will always spend the match playing in at least one of the areas of the field. Ignoring the ability to hang/elevate, the general roles of the robots before the finale will be offense, defense, and "supply line." It is equally important to be able to defend as to score, but in order to score you must have a supply of soccer balls.
In the back you will want to run into the opponent, and launching the ball is going to be more important, and you probably won't care about avoiding the opponent (you are the hunter). You will want to be able to maintain a pin for close to the maximum amount of time.
In the Front Field you will probably actively avoid the opposing defense. You are the hunted, but you have a target of your own. I think some method of herding while possibly the ability to possess/launch a short distance will be important. Mobility here will be important to avoid a pin, but escaping a pin may also be important.
In the mid field, you will need to do a little of both. You will track down the other supplier if you want to deny the supply of balls to the opposing alliance. You will avoid them when you are going to supply your offensive bot. I can see robots that are built for this task being able to be effective on every area of the field.
BTW, the directions are kind of reversed since your goal is toward you and not away from you.
Unread 09-01-2010, 19:39
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Our team came up woth the obvious soccer names:
1. Defender
2. Midfielder
3. Forward
of course then you have to take into account multi-ability robots like 1 and 2 or 1 and 3 or 2 and 3 or 1, 2, 3 robots. Those robots i would classify as the Beckham-bots
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 09-01-2010, 19:47
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
#1. kickers
#2. Goalies
#3. multi hangers
and the multi-taksers shall rule them all!
Unread 09-01-2010, 19:50
#1. kickers
#2. Goalies
#3. multi hangers
Agreed with these. Also agreed with Ed about the multi-taskers ruling the game (although goalie + hanger is a deadly combo too)
Unread 09-01-2010, 22:53
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Folks,
Please don't be shy about posting your ideas in this thread - As we update the 5th Gear match simulator (2009 5th Gear thread) for this season we are having to guess at the answers to this exact topic, so that we can give the simulated robots the right capabilities.
Keep tossing out ideas about different robot styles, robot functions or game play strategies so that we can soak them up and give you a better simulator.
Blake
Unread 09-01-2010, 22:57
Chris is me's Avatar
AKA: Pinecone
Originally Posted by gblake View Post
Folks,
Blake
gblake, would it be alright if I PMed you ideas I may not want to put in the thread at this time, but I'm guessing will be competitive?
To contribute, I believe this game will of course be ruled by a team that multi tasks well. However, doing a single task extremely well is often better than doing a multi task in mediocre fashion. I believe there will be robots that primarily shoot, interact with the bar with or without teammates, or push balls. The latter will be useful strategically in the center of the field for ball control, as it's very beneficial to have balls on one end of the field. I can see an alliance of a super shooter, a bar interaction robot with limited shooting, and a robot specializing in ball control winning events.
Unread 09-01-2010, 23:06
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
A few that I was toying with.
Offense - Pretty self explanatory (no sub-group ideas yet)
Defense (see below for sub-groups I came up with)
-Guards: bots who do the best they can to limit movement between sections
-Goalies: Guard goals
Utility
-Hangers: Bots who are both very good climbers, but also easy to climb on.
-Conveyors: middle area bots used to syphon game pieces along.
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 09-01-2010, 23:09
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
It's more than alright - Please do
FYI - Robot capabilities that you/anyone might describe are what might make their way into the simulation (if they aren't too complex for our current physics, etc. or for operating using a single XBox controller - We do have limitations ); but specific strategies that take advantage of combinations those capabilities won't be part of the game - Strategy comes from those 5.4 million hours of brainpower Dave Lavery talked about. 5th Gear users have to develop/explore their own strategies.
Also, like last year, 5th Gear won't be released until the 2nd half of the build season.
Finally, remember the long-view Dave, Woody and Dean emphasized. We win individually when we all succeed 5-10 years from now. Donating a good idea to the community just might be more rewarding than playing your cards close to your vest. I know I could be convinced to give out a few rep points to posters who do that.
So - Yes please post or PM your ideas and be part of this year's successes.
Blake
Unread 09-01-2010, 23:19
Passion Passion is offline
Jim Zhou
FRC #2198
Passion has a spectacular aura aboutPassion has a spectacular aura aboutPassion has a spectacular aura about
There are different ways of "kicking". Of course, when they say kick, people right away think of how a human would kick, which was demonstrated on Today's presentation.
Our ideas of output system, would be securing the soccer ball against a piston, and then when time is right, the piston pushes the ball straight into the goal post. We just thought of this idea today, it is definitely much more sophisticated than this.
We had slightly considered of going defense, but what if our robot is the only defensive robot on the team?
I am sure it would be very hard for the our robot to defend two goal posts to prevent 3 robots scoring...
Speaking of that, I don't recall reading anything about this in the rules; is it legal to have all 3 robots that are on the same team to be on the same segment of the field?
By segment, I meant such as end zone, or mid-field, or scoring-zone
Unread 09-01-2010, 23:30
EversmannJ's Avatar
EversmannJ EversmannJ is offline
FRC #2583
EversmannJ is an unknown quantity at this point
I think these will become important. Ball control is always extremely useful in a game like this, if a Midfielder can't hit the goal consistently than their main objective should become "move as many balls to the opponent's side of the field as possible." A very simple way to do this would be herding (possibly kicking without an upwards angle) through the tunnels. A constant flow of balls into the center of the field would make the Forward's job much simpler.
EXPERIENCE:
It's what you get when you don't get what you wanted.
Aaron Lussier's Avatar
Happy Birthday! Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Just had a wacky idea.
A fast goalie bot, that has different hanging attachments to suit partners. Also, be strong enough to support the 400 some odd pounds.
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 10-01-2010, 00:20
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
I agree, you will also have the one magical team that can do it all , and do it well ( we have seen 71 do it a few times)
Altho I do feel that some times might find a slight shame in playing goalie. I think that a decent box bot could go very far in this game. As we have all heard before, " Defense wins Championships"
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 10-01-2010, 00:21
ssa3512 ssa3512 is offline
AKA: Steve
FRC #2537 (RAID)
ssa3512 is an unknown quantity at this point
Given the maximum weight of ANY fieldable robot is 120 pounds, I would think you would only need to support a total of 360 pounds from your lifting device, and 240 from any part of the robot that another robot would attach to (assuming that the third robot attaches to the second one)
Robot-to-robot and robot-to-trailer GaryVoshol Rules/Strategy 11 06-01-2009 19:18
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
Can an a robot take a tetra from another robot in their allinace? Koko Ed Rules/Strategy 3 10-01-2005 23:01
Robot Gallery from the 2003 robot expostion in Tokyo, Japan Andrew Rudolph Chit-Chat 1 04-12-2003 15:22
