Go to Post Like my programming class teacher has said multiple times: "Stop complaining on reddit about your code not compiling and actually fix it". - [more]
Unread 09-01-2010, 23:55
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
Formula for Lifting Two Other Robots
I am trying to figure out a formula for the gears ratio that I would need.
I think a formula should involve torque in someway. Can anyone help me?
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 10-01-2010, 00:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Formula for Lifting Two Other Robots
Gear ratio should be output torque/input torque.
You want to be operating at the max power point of your motor to lift the fastest for any particular load. This is because Power = Force x Speed. Your force is constant (ish) so maximizing power maximizes speed.*
So, max power on our DC motors is at 1/2 the stall torque. So you know the input torque you want to gear for is 1/2 your stall torque.
Your output torque.. depends on the weight you're lifting and the radius/pitch/other of your mechanical system. If you're using a pulley, the output torque is weight * pulley radius.
So, your ideal gear ratio is 2 * weight * radius / stall torque. If you get, say, a 3 from this equation, then you gear for 3 turns of your input for every 1 turn of the output.
*NB: This is not to say that if you gear for maximum power lifting of 3 robots, you'll lift slower when you lift 1 robot. It just means you'll lift 1 robot slower than if you'd geared for lifting 1 robots.
Unread 10-01-2010, 00:09
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
Well it really depends on how you lift them. Let's say you are lifting two robots at maximum weight straight in the air with one winch-type mechanism. I think with batteries and bumpers, that would end up to be about 300 pounds. So you take the radius of the output shaft of the winch which the cable is wrapped around and multiply it by the weight. This will give you the torque necessary to raise the two robots. (do a quick unit check and make sure you get either in-lbs, ft-lbs, newton-meters, or some other force unit multiplied by a distance unit).
That was for a very specific way of lifting the robots. Like I said, it depends how you want to lift them. You're on the right track though thinking torque. Try a wikipedia search about gear ratios. That should help also. Good luck!
Other uses for robots a kenny03 General Forum 20 30-11-2009 21:18
Building Two Robots/Rookie Team Looking for Advice teamursamajor General Forum 2 10-01-2009 17:10
Video of FRC488 lifting two robots Madison Robot Showcase 15 08-01-2008 16:45
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
Vex Components For Other Robots Robots_R_Us Technical Discussion 7 31-05-2006 17:56
