Go to Post I feel that the only friends I have ever had are people I know through FIRST. Being on a team gave me the sense of belonging that I thought I didn't even need. FIRST has given me a great life that I never thought I would have. - Alaina [more]
Unread 10-01-2010, 00:09
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
Re: Formula for Lifting Two Other Robots
Well it really depends on how you lift them. Let's say you are lifting two robots at maximum weight straight in the air with one winch-type mechanism. I think with batteries and bumpers, that would end up to be about 300 pounds. So you take the radius of the output shaft of the winch which the cable is wrapped around and multiply it by the weight. This will give you the torque necessary to raise the two robots. (do a quick unit check and make sure you get either in-lbs, ft-lbs, newton-meters, or some other force unit multiplied by a distance unit).
That was for a very specific way of lifting the robots. Like I said, it depends how you want to lift them. You're on the right track though thinking torque. Try a wikipedia search about gear ratios. That should help also. Good luck!
Other uses for robots a kenny03 General Forum 20 30-11-2009 21:18
Building Two Robots/Rookie Team Looking for Advice teamursamajor General Forum 2 10-01-2009 17:10
Video of FRC488 lifting two robots Madison Robot Showcase 15 08-01-2008 16:45
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
Vex Components For Other Robots Robots_R_Us Technical Discussion 7 31-05-2006 17:56
