Go to Post Engineering is NOT manufacturing. .... It is good to be able to fabricate things with your own hands, but thats not what engineers do. - KenWittlief [more]
Unread 10-01-2010, 00:45
jackshamu jackshamu is offline
FRC #0995
jackshamu is an unknown quantity at this point
Confusing rule: Finale Configuration
FINALE CONFIGURATION 84 inch (213.4cm) diameter vertical right cylindrical volume
What is right cylindrical volume? Is there a wrong/ left one? 0.o
Totally confused
Unread 10-01-2010, 00:47
Re: Confusing rule: Finale Configuration
Totally confused
Geometry.
Take a piece of paper and wrap it around a soda can. You have a right circular cylinder.
Right refers to the angle of the long axis (or height) to the base plane.
Unread 10-01-2010, 01:16
FRC #0995
So a robot with length 38 would be able to reach 23 inches away from the longest side in a straight line perpendicular from the center before violating the rule?
I got 23 through
38/2=19 half the lenght
84/2=42 half the diameter
42-19=23 half the diameter minus half the lenght
it would also be able to reach a max of 28 inches from the width if its width is 28 inches
Unread 10-01-2010, 01:26
I got 23 through
If your robot is centered on the cylinder, yes. Note, however, that you are wasting a lot of reach doing this.
A longer-reaching, though harder to work with, geometry is this: Take the back side of the robot and place it so the corners are on the circle (the base of the cylinder). This forms a secant of 28". Now run a line right down the middle of the robot to the far side of the circle. The length of that line is the reach you have to work with.
Unread 10-01-2010, 01:32
jujuninja's Avatar
jujuninja jujuninja is offline
AKA: Dakota
FRC #1569 (Haywire)
Team Role: CAD
jujuninja is an unknown quantity at this point
We had to have a guy in PHD physics to help us out the best way i could think from him said is. Take a pop can put it on a cd or dvd and you can tilt it in different but u cant leave the parameters of the disk.
Kit Of Parts: $6,000
Buy Food for Those Late Nights: $150
Paying for the bus ride to Atalanta: $400
Loving the Blood, Sweat, Tears for Being On a F.I.R.S.T. Robotics Team: Priceless
e
Unread 10-01-2010, 01:34
But it's defined relative to the robot (<R10>), so tilt the CD with the can.
IE is confusing me :((( eternalearth888 Website Design/Showcase 5 14-03-2009 15:56
Confusing Video Bochek Technical Discussion 13 14-02-2007 13:36
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
One Confusing Math Problem Bharat Nain Math and Science 4 01-02-2004 17:21
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
