Confusing rule: Finale Configuration
FINALE CONFIGURATION 84 inch (213.4cm) diameter vertical right cylindrical volume
What is right cylindrical volume? Is there a wrong/ left one? 0.o Totally confused |
Re: Confusing rule: Finale Configuration
Take a piece of paper and wrap it around a soda can. You have a right circular cylinder. Right refers to the angle of the long axis (or height) to the base plane. |
So a robot with length 38 would be able to reach 23 inches away from the longest side in a straight line perpendicular from the center before violating the rule?
I got 23 through 38/2=19 half the lenght 84/2=42 half the diameter 42-19=23 half the diameter minus half the lenght it would also be able to reach a max of 28 inches from the width if its width is 28 inches |
A longer-reaching, though harder to work with, geometry is this: Take the back side of the robot and place it so the corners are on the circle (the base of the cylinder). This forms a secant of 28". Now run a line right down the middle of the robot to the far side of the circle. The length of that line is the reach you have to work with. |
We had to have a guy in PHD physics to help us out the best way i could think from him said is. Take a pop can put it on a cd or dvd and you can tilt it in different but u cant leave the parameters of the disk.
But it's defined relative to the robot (<R10>), so tilt the CD with the can.
| IE is confusing me :((( | eternalearth888 | Website Design/Showcase | 5 | 14-03-2009 15:56 |
| Confusing Video | Bochek | Technical Discussion | 13 | 14-02-2007 13:36 |
| Confusing Compiler Error | UrsaMNet | Programming | 2 | 28-10-2004 14:32 |
| One Confusing Math Problem | Bharat Nain | Math and Science | 4 | 01-02-2004 17:21 |
| Ahh! Program trick confusing! | archiver | 2001 | 9 | 24-06-2002 02:26 |
