Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Unread 10-01-2010, 08:01
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Using LabView v9 vs v8.6
The ship kit came with Labview version 8.6 and I already have version 9 installed for my work. Does anyone know of a reason why I cannot use version 9? Are there compatability problems with any other software?
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 10-01-2010, 09:56
Re: Using LabView v9 vs v8.6
I'm not sure if it is possible but in the long run, even if you could get it to work, I think it would be far simpler to use the FRC version. NI has said before that there should be no issues installing the FRC version along side a newer or older version of LabVIEW.
The FRC version of LabVIEW comes with several different toolkits (or portions of the toolkits). It has the RT, control design & simulation, FPGA, Vision, and I might be missing a few. FRC requires that you use a certain cRIO image, which is installed with the FRC LabVIEW. I'm not sure if this image which is based on 8.6 can load and run VIs built with 2009.
It's also important that you are using the same version of LabVIEW as your students so you can better help them.
If you're really interested in taking this on, I'd suggest you ask at the NI forums at http://www.ni.com/first
Unread 10-01-2010, 14:54
The issue(s) that are likely to occur will more likely be caused by driver issues than LV. I believe it is pretty important to use the same version of VISA on both the cRIO and the host, and since the drivers are rev'ed from time to time, installing more than one version of LV is a sneaky way of updating the old LV to use new drivers. Many times things are fine, but this hasn't been tested that much except on our development computers. It is unlikely that beta testers or formalized testing focused on this.
Greg McKaskle
Unread 12-01-2010, 21:14
ASTDan ASTDan is offline
ASTDan is an unknown quantity at this point
Don't install the FRC LabVIEW version if you have Regular LabVIEW on your machine. Create a virtual PC and install the FRC version on that. It will save you much pain and anguish.
http://www.microsoft.com/windows/virtual-pc/
Using Tables in LabView. Burmeister #279 NI LabVIEW 6 18-03-2009 05:22
Using Limit Switches in LabVIEW VeedotJaydot NI LabVIEW 2 14-02-2009 16:01
Using Run in Labview cabbagekid2 FRC Control System 5 07-01-2009 13:05
Using LabView to Teach Students.. Sykan NI LabVIEW 1 22-09-2008 12:14
Using the CMU cam in LabView VeedotJaydot Technical Discussion 1 10-09-2008 16:39
