Go to Post I tried to make them look at disgruntled as possible. - Katie_UPS [more]
Unread 10-01-2010, 09:40
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Driver station missing VIs
Our driver station automatically comes up in the Driver acount.
And the Driver Station software is missing two sub-VIs: Read from FRC IO.vi and Write to FRC IO.vi.
How can I stop the automatic log in to the Driver account?
Where are two missing VIs?
Unread 10-01-2010, 09:43
Re: Driver station missing VIs
The automatic login is bypassed by holding shift while booting. It seems more likely that those VIs are broken by the missing nicyapi.dll. This may have to do with the order of updates. We have a few reports of this and we are looking into it. Someone else on the forums may already have a solution. My advice if you can't find anything else would be to use Add/Remove Programs to uninstall the Driver Station from the National Instruments section, and then reinstall.
Greg McKaskle
Unread 10-01-2010, 12:28
rpcoe rpcoe is offline
FRC #0028
rpcoe is an unknown quantity at this point
I found that when you are in the DS mode, if you hold CTL,ALT,DEL, you will exit to Windows.
Unread 10-01-2010, 15:35
Note that feature changed a bit between when the laptop image was prepared and the current update. The laptop version expected teams to use Ctl-Alt-Del. The updated version has an exit button on the setup tab.
Greg McKaskle
Unread 10-01-2010, 16:15
FRC #2435
Greg,
You are right.
The nicyapi.dll is the missing dll.
Thanks
Unread 10-01-2010, 22:06
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
Greg McKaskle
Here's NI's answer to this missing file:
http://decibel.ni.com/content/docs/DOC-8891
Unread 11-01-2010, 21:00
FRC #2435
We downloaded the .dll and that fixed our problem.
Thanks to everyone.
Driver station... the man Control System 16 06-01-2010 21:06
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
driver station corps FRC Control System 5 06-08-2009 20:44
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
DAQmx VIs missing Barry Lazzer LabView and Data Acquisition 2 30-01-2007 13:06
