Go to Post I don't care if students, engineers, my aging grandmother, or a pack of monkeys builds the robot...as long as at least one student walks away inspired then the goal of FIRST has been reached. - Andy Grady [more]
Unread 10-01-2010, 07:01
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
Team Role: Driver
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
pic: 2010 Break Away
Unread 10-01-2010, 07:03
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: pic: 2010 Break Away
The hump in New Hampshire seemed steeper. I did not measure it, but I was surprised that the drawing says 45.
Unread 10-01-2010, 09:56
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Yeah, i deff agree here, it seemed wayyy steeper in manchester. More than 45
Unread 10-01-2010, 11:26
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
It also seemed a lot steeper at kickoff at Northeastern (Boston). I think the mock up in the OP is wrong.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 10-01-2010, 11:35
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Agreed!
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 10-01-2010, 11:52
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Originally Posted by bhsrobotics1671 View Post
Agreed!
36" wide bump would agree with 45 deg. 12" per ramp and 12" at top.
Each ramp would be 12" high and 12" wide...... 45 Deg.
Phil Malone
http://www.GEARSinc.org
Unread 10-01-2010, 12:18
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
I agree with whats in the blueprints... if anything I think what was built was incorrect.
Remember back in 2006 in AIM HIGH, the ramps at either end of the field were really steep, but they were only 30 degrees. I know I was shocked to see how steep 30 degrees really was...
I think the mind might be playing tricks on you, but the angle should be 45.
Cold Fusion's 10th Season
Unread 10-01-2010, 12:38
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
does the ramp actually have a bump before getting onto it?
Unread 10-01-2010, 12:43
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Yes, there is a 1/2" transition between the carpet and the bump.
Unread 10-01-2010, 16:52
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
These ramps were cut from the blueprints using our water jet. Inaccuracies are possible, but it was used as a guide for teams to start their design process.
Good luck teams
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 11-01-2010, 16:01
cinderblock cinderblock is offline
Team 8 2006 Captain
AKA: Cameron Tacklind
FRC #0008 (PALY Robotics)
cinderblock is an unknown quantity at this point
Send a message via AIM to cinderblock
Notice that the picture looks slightly rolled to one side. This I think makes this ramp look less steep than it is.
Unread 12-01-2010, 10:26
andrew348's Avatar
andrew348 andrew348 is offline
"Oh Boom, Right There"
AKA: Andrew Ewing
FRC #0348 (Norwell Robotics) ; FRC #1493 (The Falcons)
andrew348 is a splendid one to beholdandrew348 is a splendid one to beholdandrew348 is a splendid one to beholdandrew348 is a splendid one to beholdandrew348 is a splendid one to beholdandrew348 is a splendid one to beholdandrew348 is a splendid one to behold
My team just built one from the blueprints and it seems about the same. I think it might just be the camera angle it was shot from.
Unread 13-01-2010, 20:51
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Did i build our team's bump wrong or is the manual just wrong in saying the bump is 12" high? Going off the team field drawings given by FIRST the "rib" as they call it, or ramp supports are 12 7/16 high then when assembled with a 3/4" piece of ply laying on top leaves the height of the ramp at almost 13 1/4". More than an inch difference from the supposed 12" high ramp used in this year's game. Has anyone else had this problem? Is the drawing, manual, or (verly likely) me wrong?
Also the 1/2" transition from the field to the playing field. How far from the bottom of the ramp does the base plate extend? The reason I'm asking is because depending on the distance of the 1/2" transition from the bottom of the ramp it will greatly effect how the ball rolls to, and up the ramp.
The section in the manual im referencing to for the 1/2" transition is The Arena, Section 6.2.3:
6.2.3 The BUMPS
Two BUMPS are located at approximately one-third of the length of the FIELD. Each BUMP is 12 inches high, 12 inches wide at the top, and extends across the spaces between the TOWER and the Guardrail System. The BUMPS are covered with the same carpet as the rest of the FIELD (although of different colors - red and blue). Each BUMP is colored red or blue, corresponding with the color of the nearest ALLIANCE STATION. The BUMPS are fixed to base plates that are secured to the carpet of the FIELD to keep them from moving. The base plates are covered with the same carpet as the FIELD. Note that this forms a small (approximately ½-inch tall) transition from the FIELD surface onto the base plates.
The bump is confusing me so much this year. Maybe this will further help you understand what I'm asking for the second part if you still don't know what the heck I'm talking about.
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
pic: If you break your Moon rocks fordchrist675 Extra Discussion 1 30-01-2009 22:05
pic: 1636 Give Away Design LightWaves1636 Extra Discussion 5 28-02-2007 11:08
pic: camera locked on light 143ft away!!! kborer22 Extra Discussion 18 08-07-2006 14:49
pic: The Referees Taking A Break BandChick Extra Discussion 6 22-05-2006 00:00
pic: (447) Innovation Break rufu5 Robot Showcase 15 19-02-2005 22:57
