Go to Post neato. - ebarker [more]
Unread 09-01-2010, 18:35
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Tower Dimensions
Hello. While brainstorming with my team, I came across what seems to be a contradiction in regards to the dimensions of the tower. If you look in 6.2.4, it states that
The PLATFORM is 44 inches wide by 36 inches deep
I took this to mean that the tower also holds these dimensions for length and width.
However, if you look at the detailed field drawing, specifically GE-10028, it shows that the top of the tower, which extends vertically from the corners of the platform, forms a square.
Furthermore, in 6.2.4 it states that the tunnel is 36 inches wide, which would imply that the bars of the tower are also 36 inches apart. And if you look at the GE-10047 in the detailed field drawings, it shows on the second page that the bump is 36 inches wide, which means that the bars of the tower are 36 inches apart in that direction as well. This supports the drawing of the top of the tower being a square, but it goes against what the manual states, so I am left confused about the true dimensions between the bars. Can anyone help me to clarify this?
Unread 10-01-2010, 06:21
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Tower Dimensions
Good catch, I think.
The area cad drawing will be the definitive resource here, so I think your 36x36 is more likely correct.
The low cost drawings should be able to confirm it too.
Unread 10-01-2010, 10:15
dromias dromias is offline
FRC #1835
dromias is an unknown quantity at this point
Happy that I am not the only one struggling with this.
The PLATFORM is 44 inches wide by 36 inches deep, and is at a height of 20 inches above the floor. A 36-inch wide by 18-inch tall TUNNEL under the PLATFORM, providing a passageway between the MIDFIELD and the adjacent end ZONES.
I would have assumed that the 36" of the platform would coincide with the side of the tunnel that is equally 36". However I am confused as to whether or not this refers to the front and back or the left or right of the platform.
I would also have assumed that when describing the 'depth' of the platform it would be the right and left of the platform, but from the above quote, this would be wrong..
Along with Kpchem's find in the game field docs, I am really confused about the tower dimensions as well as the orientation of the entire tower.
For now, I am also willing to believe that the 44" was a mistake, and that it's really 36"x36".
Unread 10-01-2010, 10:32
carbuff2228's Avatar
carbuff2228 carbuff2228 is offline
Scouting Mentor -College student
FRC #2228 (Cougartech)
Team Role: Scout
carbuff2228 is on a distinguished road
the towers height i know is 86 inches
Unread 10-01-2010, 10:44
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Perhaps the 44" refers to little "wings" that extend the platform onto the top of the bumps? the tower itself can still be 36" square and centered on top of a 44" wide platform.
I'm still downloading all the docs, and haven't gotten to that one yet.
Unread 10-01-2010, 11:34
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
The tower is 7 ft tall therefore its actually 84 inches
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 10-01-2010, 12:38
FRC #1835
While we're talking about this, does anyone know the bottom dimensions of the bump? I figured it was the same size as the width of the tower, since they seem to match up in the docs. But anyone have a more solid idea? In the user manual I believe it just mentions the height is 12" and the top of the bump is also 12".
Unread 10-01-2010, 14:46
ishron ishron is offline
FRC #1899
ishron is an unknown quantity at this point
Please correct me if I am wrong here..
Each side of the tower tunnel has a Bump which is actually 3 Bump Assemblies.
Bump dimensions:
Base = 36in X 46 1/2in
Height = 12in
Slope = 18in X 46 1/2in @ 45deg
Top = 12in X 46 1/2in
from GE-10047.PDF
Unread 10-01-2010, 15:04
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Another thing...
If you will look carefully at the drawings of the tunnel you will see that the material it is built from is wide (looks like a wood or w/e...), and the INNER dimensions of the tunnel is 36" wide (According to the manual) which means the outer width has to be larger, which is also the platform width.
so lets say the width of the material the tunnel is built from (Or the total width) is 4" then it is 36"(Inner width) + (4"(Material width) * 2) with comes to the total of 44" which is the platform width as written in the manual.
Hope it helps
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 10-01-2010, 15:29
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
This photo from the Kickoff may be useful:
Unread 10-01-2010, 15:42
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
thanks for that photo. It's quite useful. It also alters one of my design ideas... back to the board.
Popsicle Stick Tower merybar General Forum 25 17-03-2008 22:14
Icy Tower DanDon Chit-Chat 16 02-11-2006 14:05
[OCCRA]: tower dimensions mikaela50 OCCRA Q&A 1 26-09-2005 16:16
pic: New Tower Iain McLeod Robot Showcase 1 12-02-2005 07:01
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
