Go to Post Andymark has everything! - nighterfighter [more]
Unread 10-01-2010, 11:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Steel Frame
We've been kicking around the idea of making the robot frame this year out of steel, or a combination of steel and plywood. Thinwall (1/16") square steel tubing is a bit heavier per unit length than thickwall (1/8") square aluminum tubing, but it offers several advantages that might make the few extra pounds well worth it.
Like plywood, steel tubing is easy to get locally, and also like plywood, it's relatively easy to work with. Welding it together with the MIG process does not require as much skill as welding aluminum, and the equipment for welding steel is more commonly available (I have a 140 amp gas MIG welder in my home shop, as do many of my friends).
To mount brackets, axles, and such just requires welding on a piece of steel. Cantilevered axles can be made by simply welding a bolt to the lower edge of the tubing. Brackets for mounting transmissions can be steel strap with holes or slots cut in them.
If you see some weird steel chassis prototypes showing up in the next week or two, don't be surprised!
(I did search for other posts on the subject, the previous one that seems to be most applicable http://www.chiefdelphi.com/forums/sh...ad.php?t=60165 is locked)
Unread 10-01-2010, 11:50
wendells's Avatar
wendells wendells is offline
FRC #2185 (RAMAZOIDZ)
wendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to all
Re: Steel Frame
I love your idea, thinking outside the box, allows you to do many things
Unread 10-01-2010, 12:14
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Steel Frame
Steel does sound attractive this year. The robots will take quite a beating with the whole defensive part of the game. Remember 2007? I do not know about you guys, but our robot was falling apart in the end with an 80-20 aluminum chassis. Some other metal than aluminum is probably the best way to go this year.
Unread 10-01-2010, 20:17
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Steel Frame
I don't know about that... We used 80.20 that year too, and it held up alright during the competition. It wasn't until the next year when it started falling apart
Since then, we haven't used any 80/20, but everything has still been aluminum (except for our steel weights to get up to 120 lbs), and none of them have had a problem with falling apart. Welding aluminum can make it plenty strong!
Unread 10-01-2010, 20:26
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
Steel is probably not a good choice for teams that have the equipment and ability to make a nice welded aluminum frame. There are plenty of teams that do not.
Unread 11-01-2010, 12:59
Re: Steel Frame
Completely agree with you there, squirrel. Teams should go with whatever they have the ability to make. My point was that the problem Cyberphil had wasn't with aluminum - it was with 80/20. That stuff was designed to be very flexible in configuration, but you lose a lot of durability for that.
For that matter, I've seen teams build durable robots with kitbot frames and plywood. Play to your teams strengths and abilities
Unread 11-01-2010, 13:27
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Steel Frame
1501 has used steel tubes before and they worked very well. Search for picks of their frame on the RacknRoll bot.
Unread 11-01-2010, 13:30
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
I have some pictures of their steel frame that I took in Atlanta that year...they used round, strong alloy tube (chrome moly) and gas welded it. I think we won't get quite that fancy.....
Unread 11-01-2010, 13:32
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Steel Frame
Steel is good for many things and a frame could be one of them. I always choose what to make mechanisms out of based on what the design needs are not necessarilt what is lightest, because sometimes stell is lighter than aluminum for the given purpose. One of my favorite tricks is to us 4130 aircraft grade round steel tubing for a structure if it's under high loading because it would take a lot more mass of AL tubing to get the same strength and durability. Just remember to consider wall thickness....
Squirrel: You may want to use this as well as it is easily weldable. We usually TIG but you should be fine MIGing it.
Also McMaster carriers it: http://www.mcmaster.com/#grade-4130-...tubing/=5bx00i
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 11-01-2010, 13:46
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
I would guess that using 4130 would allow us to use a thinner wall, for a lighter assembly with the same strenght. The downsides are that it's kind of difficult to MIG weld structural parts with less than 1/16" wall thickness, and that it's not available in town...which is a concern for us, especially during the prototyping phase.
I agree that it's wise to pick the best material for each part of the robot. There are a lot of things to consider....weight, strength, ease of fabrication/machining, ease of attaching other parts, cost, availability, repairability, etc.
Unread 11-01-2010, 13:47
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Steel Frame
I think steel is perfect for the robot who decides to be elevated and then who decides to lift two other robots a couple inches off of the floor. With a safety factor of two, that's 900lbs* the tower connectors will need to support. It's well worth the additional weight for a bot who's lifting other bots due to the compactness of strength alone. Score 8 points for the home team!
*120lbs (robot) + 14lbs (battery) + 20lbs (bumpers) = 154lbs... time three robots = 462lbs pre-safety factor
GitHub
Unread 16-01-2010, 23:45
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
Started on the prototype steel frame, we're moving in slow motion this year....
One axle is welded on.
Unread 17-01-2010, 14:16
silv940's Avatar
silv940 silv940 is offline
AKA: Sam Wilkins
FRC #1572 (Hammer Heads)
silv940 is an unknown quantity at this point
Send a message via AIM to silv940 Send a message via Yahoo to silv940
Re: Steel Frame
We used chromoly steel (most bicycles are made out of it) and it welds very nice with a MIG. The welds are nicer than steel and it is stronger.
Unread 17-01-2010, 14:55
MrForbes's Avatar
AKA: Jim
Re: Steel Frame
Did you normalize after welding?
Unread 17-01-2010, 15:28
silv940's Avatar
AKA: Sam Wilkins
Re: Steel Frame
I don't understand the question
Steel Frame? gburlison Technical Discussion 20 18-12-2007 16:56
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Steel Blends Wetzel Technical Discussion 2 15-09-2003 17:01
steel tubing BBFIRSTCHICK Rules/Strategy 2 14-01-2003 22:03
Steel Edge AJ Howard Rules/Strategy 1 18-01-2002 18:52
