Go to Post Stupid rules are still rules. They're not meant to be broken, they're meant to be changed. - Alan Anderson [more]
Unread 10-01-2010, 12:28
rpcoe rpcoe is offline
FRC #0028
rpcoe is an unknown quantity at this point
Re: Driver station missing VIs
I found that when you are in the DS mode, if you hold CTL,ALT,DEL, you will exit to Windows.
Unread 10-01-2010, 15:35
Note that feature changed a bit between when the laptop image was prepared and the current update. The laptop version expected teams to use Ctl-Alt-Del. The updated version has an exit button on the setup tab.
Greg McKaskle
Unread 10-01-2010, 16:15
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Greg,
You are right.
The nicyapi.dll is the missing dll.
Thanks
Driver station... the man Control System 16 06-01-2010 21:06
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
driver station corps FRC Control System 5 06-08-2009 20:44
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
DAQmx VIs missing Barry Lazzer LabView and Data Acquisition 2 30-01-2007 13:06
