Go to Post What happens on your team is not everyone's business!!!! - Bruneau1727 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2010, 14:11
Re: Axis 206 Web Camera no longer in production
R68
All outputs from sensors, custom circuits and additional electronics shall connect to only
A. other custom circuits, or the following:
B. additional COTS electronics, or
C. input ports on the Digital Sidecar, or
D. input ports on the Analog Breakout, or
E. the RS-232 DB-9 serial port on the cRIO-FRC, or
F. the Ethernet bus connected to Port 2 of the cRIO-FRC, or
G. the CAN-bus if and only if all Jaguar speed controllers on the CAN-bus are wired in full compliance with Rule <R63> and Rule <R64>.
Custom circuits and additional electronics are allowed to utilize the Port 2 Ethernet bus and/or the CAN-bus to communicate between devices. Note however, that the ROBOT must be controlled by the cRIO-FRC (see Rule <R56>). Thus, any additional devices on the Ethernet or CAN-bus must not provide command signals that do not originate from the cRIO-FRC It is our intent to incrementally open access to the full control system technologies in a controlled manner that reduces the risk of “unanticipated surprises” as we gain experience with the system.
R68 looks to allow "whatever" to be attached to ethernet 2.
My interpretation would be that it is legal to use any camera that doesn't violate other rules.
Axis Web Cam Tom Line Control System 4 17-10-2009 21:56
Axis Camera ehochstein Programming 2 21-02-2009 00:16
Need help with Axis 206 Power Adapter dipmeinaluminum FRC Control System 1 21-01-2009 20:01
Programing servo in Axis camera 206 frcchile NI LabVIEW 6 18-01-2009 08:53
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
