Go to Post I survived the Great CD Spamming of 2006. - Michelle Celio [more]
Unread 10-01-2010, 14:33
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Pic: Flippable robot
BUMPERS – Bumper assemblies designed to attach to the exterior of the ROBOT within the BUMPER ZONE, and constructed as specified in Rule <R07>. BUMPERS are excluded from the weight and volume calculations specified in Rule <R10>.
BUMPER ZONE – the volume contained between two virtual horizontal planes, ten inches above the floor and sixteen inches above the floor.
NORMAL CONFIGURATION – The physical configuration and orientation of the ROBOT when the MATCH is started. This is the state of the ROBOT immediately before being enabled by the Field Management System, before the ROBOT takes any actions, deploys any mechanisms, or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH).
R07
A - BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor, and must remain there (i.e. the BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE).
F - The only markings permitted on the BUMPER fabric cover are the team number (see Rule <R15>).
R15 - Teams shall display their team number on the BUMPERS in four
locations at approximately 90-degree intervals around the perimeter of the ROBOT. The numerals must be at least 4 inches high, at least in ¾-inch stroke width and in a contrasting color from its background. Team Numbers must be clearly visible from a distance of not less than 100 feet, so that judges, referees, and announcers can easily identify competing ROBOTS.
Now for the pic -
The only problem in the rules I see is R15, and we'll have to make numbers both upside down and upside right, or use an ambigram of the team number (hah!)
I think it's legal, what do you guys think?
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
pic: Summer Robot- The robot mattd7591 Extra Discussion 2 10-09-2008 08:39
pic: 166's Robot '07 Robot: Gemini Dan Petrovic Robot Showcase 4 20-02-2007 21:41
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
