Go to Post *speaks into wristwatch* We've got a non-gracious professional here, get Woodie on the phone! - Ringo5tarr [more]
Unread 10-01-2010, 14:33
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Pic: Flippable robot
BUMPERS – Bumper assemblies designed to attach to the exterior of the ROBOT within the BUMPER ZONE, and constructed as specified in Rule <R07>. BUMPERS are excluded from the weight and volume calculations specified in Rule <R10>.
BUMPER ZONE – the volume contained between two virtual horizontal planes, ten inches above the floor and sixteen inches above the floor.
NORMAL CONFIGURATION – The physical configuration and orientation of the ROBOT when the MATCH is started. This is the state of the ROBOT immediately before being enabled by the Field Management System, before the ROBOT takes any actions, deploys any mechanisms, or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH).
R07
A - BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor, and must remain there (i.e. the BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE).
F - The only markings permitted on the BUMPER fabric cover are the team number (see Rule <R15>).
R15 - Teams shall display their team number on the BUMPERS in four
locations at approximately 90-degree intervals around the perimeter of the ROBOT. The numerals must be at least 4 inches high, at least in ¾-inch stroke width and in a contrasting color from its background. Team Numbers must be clearly visible from a distance of not less than 100 feet, so that judges, referees, and announcers can easily identify competing ROBOTS.
Now for the pic -
The only problem in the rules I see is R15, and we'll have to make numbers both upside down and upside right, or use an ambigram of the team number (hah!)
I think it's legal, what do you guys think?
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 10-01-2010, 14:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Pic: Flippable robot
I think it'll spend all of it's time on it's side.
Unread 10-01-2010, 14:36
.999~=1
Not if it's designed well
Unread 10-01-2010, 14:45
MrForbes's Avatar
AKA: Jim
I didnt' spend enough time figuring out how to design it well. The main problem I see is that the CG will probably end up near the middle of the bumper zone, making it relatively tippable compared to a more conventional design.
Unread 10-01-2010, 14:50
kjolana1124's Avatar
kjolana1124 kjolana1124 is offline
AKA: Kelsey Jo Starr
FRC #1124 (The ÜberBots)
kjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant future
We were talking about similar ideas on our team as well. I feel like that design might distribute the weight too evenly. But maybe that's just because it's a simple idea of your design and not the actual thing. I feel that a lot of people are going to be working with these ideas, which I'm really looking forward to seeing. I also think a configuration like this would make going through the tunnell faster. But again, I also feel like it would be more effective if one end had larger wheels than the other. Like this toy:
But again, I'm not 100% sure.
On another note, I think writing your number like an ambigram would be really cool to see!
Unread 10-01-2010, 14:52
.999~=1
Mostly I made this thread for the legality of the idea, not the practicality.
Unread 10-01-2010, 15:03
The only legal issue I can think of at teh moment is the fact that you can't control balls with an active mecanism above the bumper zone. Our team interpreted that as it can be staic when it touches the ball, but can't move. What if you have those upper wheels spinning and a ball lands on them and is moved? I'm not sure if they would count it, but it is something to watch out for.
Woodie Flowers asked for Super Nerds
We're giving him ÜberNerds
~Tweeeeter~
2010 Northeast Utilities Hartford Regional Champions
2010 WPI Regional Chairman's Award Winners
2008 Archimedes Division Champions
2008 Hartford Regional Champions
Unread 10-01-2010, 15:42
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
If you can figure out a way for the bumpers to be level, and at the regulated height, at all times you'll be good.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 10-01-2010, 16:03
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Certainly a cool idea. You won't be able to go through the tunnel since you'll be 26" tall (assuming bumpers centered on 13" in both orientations), and if you're able to go over the bump, i'd be worried about balls getting caught.
you could have cool little counterweighted shields to cover the upper set of wheels.
I also agree you'll have to end up with 8 numbers unless you can make the ambigram, which is alot harder.
Also important to note is that your power switch needs to be accessed and the diagnostic light needs to be visible. Both of those requirements are possible if they are well placed.
Unread 10-01-2010, 16:16
TEntwistle's Avatar
TEntwistle TEntwistle is offline
AKA: Trey Entwistle
FRC #0433 (Firebirds)
TEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really nice
Another issue to consider is carrying the game balls. Any robot that is flippable will have the potential to carry balls inadvertantly unless you want to cover the top and bottom sides - that will really limit the chances of being compliant with other rules or to do anything other than push a ball.
It is sometimes better to be lucky than good.
Unread 10-01-2010, 17:24
afowl's Avatar
afowl afowl is offline
Forever a Mercurite
AKA: Amanda Fowler
FRC #3929 (Atomic Dragons)/FRC #1089 (Mercury)
afowl is a jewel in the roughafowl is a jewel in the roughafowl is a jewel in the roughafowl is a jewel in the rough
Can you tell me where that rule is because I can't find what you are referencing?
2007-2011: [ Team Mercury 1089 ]
2012-????: [ Atomic Dragons 3929 ]
FF: The Machine
@frc1089
Unread 10-01-2010, 17:30
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
In reference to afowl's question:
<G45> Active BALL control - ROBOTS may not control BALL direction with active MECHANISMS above the BUMPER ZONE. Violation: PENALTY.
Unread 10-01-2010, 17:34
Racer26 Racer26 is offline
My question here, is that obviously the INTENT of this rule is to not have a mechanism on the top of your robot, such as a conveyor belt, to push the ball toward your end. But the letter of the rule seems to make designing an invertable robot difficult.
also; here's another interesting way to interpret it: looking at the definition of a MECHANISM:
Originally Posted by FRC2010 Manual, Section 8
MECHANISM – A COTS or custom assembly of COMPONENTS that provide specific functionality on the ROBOT. A MECHANISM can be disassembled (and then reassembled) into individual COMPONENTS without damage to the parts.
My take on this is that the specific INTENDED functionality of those wheels was to DRIVE the robot, as opposed to them being there with the purpose of modifying the trajectory of a ball that happens to land there.
Unread 10-01-2010, 17:42
Chris is me's Avatar
AKA: Pinecone
Interesting idea, I must say.
I would be very disappointed if the concept were disallowed just because there would be upside down team numbers. That seems rather strict, but it's enough of an issue that I'd make a Q&A about it if I were you.
What if you write your number upside down and right side up on the same bumper? I think that meets the rule just fine.
Unread 10-01-2010, 21:22
Youarefunny Youarefunny is offline
FRC #0854
Youarefunny is an unknown quantity at this point
As long as the mechinism that is facing the sky isn't moving ur fine i think.
pic: Summer Robot- The robot mattd7591 Extra Discussion 2 10-09-2008 08:39
pic: 166's Robot '07 Robot: Gemini Dan Petrovic Robot Showcase 4 20-02-2007 21:41
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
