Go to Post Basically: engineering is fun. - Mike [more]
Unread 10-01-2010, 12:36
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
Examples missing
It's been a year since I last used this program. I installed windriver on my new laptop but I think something went wrong. The FRC downloader is there but the example projects are nowhere to be found.
I have some old projects which opened sucessfully but I don't have a robot available right now. The project resulted in this build error:
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** No rule to make target `G:/FRC/2009/Workspace/SimpleTemplate/MyRobot.cpp', needed by `SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o'.  Stop.
Build Failed in Project 'SimpleTemplate' (Process Exit Value was 2):   2010-01-10 09:32:56   (Elapsed Time: 00:00)
I'm worried that the installer may have neglected to include the stuff necessary for programming the cRIO. How can I fix this problem?
Unread 10-01-2010, 13:08
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Examples missing
You could try uninstalling and reinstalling windriver. I haven't run the installer yet (We don't get our hands on any equipment until Monday), but I extracted all the files within the updater and found the examples under vxworks/target/src.
I'm not 100% sure what the error means, but I think it is saying the prebuilt binaries aren't there. Try looking around the directories listed in the error
Unread 10-01-2010, 13:32
Team President
AKA: Eric Eaton
How do you uninstall wind river?
Unread 10-01-2010, 14:48
AKA: Ian Thompson
Forget about the reinstall thing. I didn't read your post closely enough and thought you were upgrading an old one.
What did you use to install Windriver? Most likely you have an old version. download the update and try that. It should erase all FRC libraries and re-load them with the latest version. Can't hurt to try
Also I heard from one of the beta teams that the new code is not 100% compatible with the old code. Old stuff might not build correctly
Unread 10-01-2010, 16:04
Team President
AKA: Eric Eaton
OK I should have read the instructions the examples are under VxWorks downloadable kernel module sample project.
NXT Mindstorm Teleop EXamples johncap100 FIRST Tech Challenge 4 10-10-2009 09:48
Woodie Flower's Award Examples Andrew Blair General Forum 10 12-01-2007 11:45
Entrepreneuship award examples Dr. Acula General Forum 12 13-01-2006 19:16
G15 explained - interference examples AmyPrib Rules/Strategy 6 23-01-2005 18:58
Team Update #20/Scoring Examples ahecht General Forum 40 05-03-2003 23:07
