Go to Post ...if two good things are good by themselves let's do them both together to make a better thing. So who's up for an apple pie burrito? - Katy [more]
Unread 09-01-2010, 18:24
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
Problems Interfacing '10 Control System w/ Classmate
Hi all,
We set up the Classmate and installed fresh software from the '10 kit, as per instructions from FIRST. We re-imaged the cRIO from the Classmate, but it refuses to interface with our controls. It throws a "No Code" error, even with a fresh re-imaging, and also with unedited sample code from FIRST.
Anyone else have this error? Anyone have a solution?
Unread 10-01-2010, 09:48
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Problems Interfacing '10 Control System w/ Classmate
Write code and put it on the robot. It needs your code
Watchdog.Kill();
Unread 10-01-2010, 12:12
TimDavis TimDavis is offline
FRC #1983
TimDavis has a spectacular aura aboutTimDavis has a spectacular aura aboutTimDavis has a spectacular aura about
Is there a URL or other means to download the driver station application? I would like to run the application on a development system laptop instead of the Classmate for testing purposes.
Tim
Unread 10-01-2010, 12:48
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Obviously, we did. I think that unedited sample code counts as code that was downloaded successfully -- WindRiver threw no errors. This is similar to the case I had before with last year's Control System about a month ago: http://www.chiefdelphi.com/forums/sh...ad.php?t=79328
Unread 10-01-2010, 13:03
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
The mandatory update for the classmate driver station also works as a standalone installer for development machines.
It can be downloaded at http://joule.ni.com/nidu/cds/view/p/id/1535/lang/en
Unread 10-01-2010, 13:15
1951-44U's Avatar
ROAR.
AKA: Phil Chang
We did install this, and even when we do it again, it detects the update already installed and does not re-install the update.
The robot is still refusing to accept code.
Obviously, we did.
The Classmate indicates that it communicates with the robot alright and the stop button is in place, but it detects no code on the robot even though we downloaded it.
Unread 10-01-2010, 15:12
The driver station (DS) has high level diagnostics on the left that summarizes communications, code, and stop button. Additional information, especially about communications is provided on the Diagnostics tab. This pings each of the elements to help tell what is wrong with the comms or USB elements.
If No Code is the message on the DS, and everything else is fine, I'd probably use the development tool to run the code, perhaps look a the serial output, until you believe that your code is running that way. One possible issue with the code starting could be the language that the cRIO was formatted for. The language selection determines the libraries and some startup settings. The Diagnostics tab displays the cRIO language settings near the version string. The updated version of the DS does anyway.
Once you have code running in the development environment, then you can focus on deployment.
Greg McKaskle
Unread 10-01-2010, 15:21
1951-44U's Avatar
ROAR.
AKA: Phil Chang
We looked on the Diagnostics tab, and under the "Robot" and "E-net Link" there are no errors (all green). We could reboot the robot and have the two indicators respond accordingly.
What's the "developmental tool"? Do we use the remote console on WindRiver? Or something else?
Unread 10-01-2010, 15:48
The detail lights in the communications column don't really offer any additional info unless you have communication error. Otherwise they simply confirm which elements are present.
I'm not sure if you are using C++, LV, or Java, but by development tool, I mean the WindRiver C++ Eclipse environment, the Java Eclipse, or the LabVIEW editor. Work through the getting started directions if needed, and execute a sample program, an example, or your own simple program.
The No Code message means that no code on the robot is interacting with the communication task. Note that code stuck at a breakpoint looks similar to this depending on the development tool.
The serial output may offer some hints as to why code isn't starting, especially for C++ and Java. Note that this year, there is a tool for sending the serial over enet and straight to a message window.
On the diagnostics tab, have you verified that the cRIO is formatted for the language you've selected?
Greg McKaskle
Unread 10-01-2010, 17:38
Bharat Nain's Avatar
We formatted the CRio to work in C/C++. When we tried to connect to the cRio using the real time target server in Windriver, here is the error:
Sun Jan 10 17:25:24 2010
    Target name is 10.0.25.2
tgtsvr (VxWorks6x_10.0.25.2@1951-44U): Sun Jan 10 17:25:24 2010
    WTX Library version: 4.1.1.22
    Tgtsvr core version: 4.1.1.17
     Wind River Target Server: Win32 version
    Connecting to the target agent ...
    ... switching to WDB4 mode ...    ... succeeded !
    Loading plug-in for VxWorks... succeeded.
     Checking License... OK
    VxWorks plugin version: 4.1.1.11
    Attaching elf OMF reader for PPC CPU family... succeeded.
Differences for module "vxWorks" segment's address 0x100000:
     Offset        Target Value    Host Value
     0x152        0x9c        0x9d
      0x153        0x84        0xd0
     0x49d        0x0d        0x09
      0x49e        0x03        0xaf
Stopping dump. Other errors might exist.
     Error: The systems running on the target and loaded into the target server memory are different.
Either wrong core file is selected on the host or text section is corrupted on target side.
Error during target server core initialization
 Target Server will exit
After that, we connected the cRio directly to HyperTerminal and recorded the output. I have attached a text file populated with errors. The last line (FTP Server Connection thread error) occured when we tried to deploy code using WindRiver.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 10-01-2010, 18:16
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Hi Bharat,
From looking at your console capture, I can see that you are loading the FRC 2009 image file onto your cRIO (or that you never reimaged it).
The errors you are getting (which prevent your code from running) indicate that it is expecting symbols from the 2010 image.
This tells me that you have successfully updated the WPILib, but not the image on the cRIO.
Go to www.usfirst.org/frccontrolsystem and click on Mandatory LabVIEW Update. In the description on that page, you'll see that this update is needed for all development languages since it contains the latest imaging tool and image for the cRIO.
After installing this update, run the imaging tool to image your cRIO with FRC_2010_v19.zip. You should then be able to deploy or run your 2010 code and control it with the classmate driver station.
Cheers!
-Joe
Unread 10-01-2010, 18:47
1951-44U's Avatar
ROAR.
AKA: Phil Chang
YES! It works, that update did the trick. I guess we overlooked it because it had Labview in the file name.
Well, lesson learned. Install any and all updates.
Unread 10-01-2010, 22:55
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
I did the updates and now the Classmate can't find nicyapi.dll. I used the DS on the programming laptop instead and I could see that the downloaded program worked on the DS executables on the laptop. Will there be an update with the proper files soon so we can get the Classmates running?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 10-01-2010, 23:52
http://decibel.ni.com/content/docs/DOC-8891
explains the issue and the solution.
Greg McKaskle
Unread 11-01-2010, 06:30
Jon236's Avatar
AKA: Jon Mittelman
Greg McKaskle
Thank you!
Jon Mittelman
[BB] So, what about the Classmate? EricVanWyk General Forum 30 13-01-2010 20:04
Classmate PC - Front Panel jmanela NI LabVIEW 28 23-08-2009 20:36
New Control System Update Problems NinJA999 FRC Control System 3 29-12-2008 23:04
New Control System Problems ExarKun666 Technical Discussion 13 23-12-2008 16:29
New Control System - Wireless Problems Ashwin FRC Control System 13 11-12-2008 10:38
