Go to Post This year may be one of the first years where there is a drastic difference in Regional level and Championship level strategies that drive robot design. - tim-tim [more]
Unread 10-01-2010, 16:41
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: Carrying <G44>
It depends, but I'm inclined to say it's not. If your robot was to turn, while the trajectory would change. It may not remain in the same location relative to the robot because it is probable that it will slip and/or roll and stay in roughly the same position that it was (absolute position). Its kind of like pulling a tablecloth from under a bunch of glasses. In addition, if you were to back up, the relative position would quite obviously change. I'd say this one would need to go on Q&A, although I'm not seeing a way to do this well because of the whole bumpers thing.
The reasoning used would also imply that in the instant that a ball lands on your robot off of a short fall such that it rolls off of your robot that it will be counted as carried. In other words, as long as the drop is short, it implies that you carry the ball for an instant in time whenever a ball for example, rolls of the platform and onto your robot regardless of a design to make it fall off.
Carrying the message of first.... OScubed General Forum 8 02-04-2009 19:44
Trailer carrying capacity Izeke0 General Forum 1 03-01-2009 23:49
Ball carrying? mad_cloversc FIRST Tech Challenge 5 01-12-2005 20:48
Carrying Tetras russell Technical Discussion 5 11-02-2005 14:21
Question: Carrying Case UIDzero Technical Discussion 10 10-11-2003 14:35
