Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 10-01-2010, 16:43
JJD JJD is offline
AKA: Jesse
FRC #2225 (R.U.S.T.)
JJD is an unknown quantity at this point
This is about as anti-gracious professionalism as you can get but....
Does anything stop a team from getting ahead by more than 2 penalties of points, driving 2 robots into the opposing teams goals, and hitting the E-stop?
It'd be a pretty terrible thing to do, and team 2225 does not plan on doing it. Just kinda a curiosity thing on my part.
-All the caffeine in the world can't fix this problem
Unread 10-01-2010, 16:46
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: This is about as anti-gracious professionalism as you can get but....
I belive you would be D-Q'd if you flagrantly did this..
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 10-01-2010, 16:50
JJD JJD is offline
AKA: Jesse
Thats what I figured. Kinda surprised it's not in the rules as a red card issued offense
Unread 10-01-2010, 17:00
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
One can only have ONE alliance robot in the far section at a time. Therefore it negates the possibility of blocking both goals.
Refer to G29
Unread 10-01-2010, 17:01
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Read the italics at the end of G29 a red card will be issued if the effort to correct problem is not immediate.
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 10-01-2010, 17:07
DonRotolo's Avatar
Back to humble
FRC #0832
And although hitting the E-Stop avoids further Penalties, a Red Card is not a Penalty.
Unread 10-01-2010, 17:13
Joining the 900 Meme Team
FRC #0079
Dave has the answer to that:
Originally Posted by Dave Lavery
The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it.
Can you? Sure. Should you? Probably not.
Unread 10-01-2010, 17:45
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Also, this strategy doesn't ensure victory. Your opponent can still get bonus points at the end from hanging.
Unread 10-01-2010, 19:05
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Note: I assume here that the refs would give you a red card for unsportsmanship-like conduct for doing this, which I don't think is a very big assumption.
It would work well for your alliance partner who didn't do it, because their robot wouldn't be red-carded, and would still receive seeding points. The two robots that did the shutdown would lose their seeding points, thus making the match worthless for them.
In the eliminations, the red card would cause your alliance to lose the match.
So I don't think this tactic would work well.
Unread 10-01-2010, 20:21
1075master's Avatar
1075master 1075master is offline
SLEEP IS POINTLESS!!!
AKA: John Nelson
FRC #1075 (Sinclair Sprockets)
1075master is an unknown quantity at this point
the following is from section 9(the tournament)
9.3.6 Seeding Point Exceptions
During the qualification matches, TEAMS can individually receive RED CARDS. A RED CARDED TEAM will receive zero seeding points and zero coopertition bonus.
You are forfeiting your teams points when you get a red card. Once again going back to the can you and should you. Your only hurting yourself by doing something like this. I would also bet that after a few red cards you may not be playing anymore.. so is it worth it... ABSOLUTELY NOT.
2004 && 2006
-driver,head design, head build, secondary programmer
year >= 2007 && year <= 2009
-mentor in every aspect
Let's Put the Professionalism back in Gracious Professionalism Katy General Forum 30 16-03-2008 14:12
What is Gracious professionalism to you? Viper37 General Forum 12 06-05-2007 20:49
Interesting story about gracious professionalism..... Adam Y. General Forum 1 20-04-2004 20:50
In the spirit of Gracious Professionalism, I give you: My MultiDrive. Sachiel7 Technical Discussion 6 14-11-2003 19:59
Gracious Professionalism about a mistake rachakate Regional Competitions 13 28-03-2002 08:49
