Go to Post We may not have a robot yet, but we have Robot Potential! - Blue_Mist [more]
Unread 10-01-2010, 16:23
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Hanging robots and <G31>
There may be some other rules as well, but be careful of the size restriction. If you shoot it too high, or you miss, will you still be in a legal size configuration?
Also if you miss, can you get it back and try again?
Specifically you'll also want to read all the entanglement rules. It's not a chance I would personally take.
as far as hanging off the posts, some robots hanging from the top bar will be putting more torque on it than something holding onto the vertical posts.
also see this pic posted by someone else: http://www.chiefdelphi.com/forums/at...2&d=1263155312
Unread 10-01-2010, 17:45
ATannahill ATannahill is offline
AKA: Alex Tannahill
Originally Posted by frank.pendzich View Post
A student just asked if the rules prevented us from shooting a grappling hook over the top of the tower and pulling us up with a cable.
Teach by example, read the rules. Also, you might want to put that in the form of a question if you want an answer.
- Arizona North
Unread 10-01-2010, 19:21
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
the max height you can extend to is 90" and the bar is at 7' i.e. 84", so unless you can get it to fire between a 6" window while staying within the 84" cylinder during the final period sure... but there are far simpler solutions.
making sure your team has a full understanding of the rules while designing is very important.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 10-01-2010, 20:21
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We're thinking about hanging off the virticle support posts on the tower. Our question is... Are the towers secured so they won't fall over with 130lb robot clamped on to one of it's verticle posts?
I think a robot in full trim should be able to hang off of one of the vertical support posts. I'd imagine, that the tower and it's mounting system was designed with a safe working load of about 900lbs or more. (900 lbs being derived from 6 robots hanging from the tower in some strange crazy illegal instance) The only thing you may experience while hanging is some slight warping of the bar, maybe a half inch to an inch at most.
Unread 10-01-2010, 20:29
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
If you're all just discussing hanging and nothing else ignore this comment, otherwise you might recall that you can be on top of the tunnel (the platform that connects to the flat area of the bumps and is inside the tower). You can still get the 2 points but you'll need to fit in there. If you're having problems with hanging try resting on the platform and having other robots ramp on top of you for the 3 point bonuses.
If i have the interpretation wrong, please tell me.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 13-01-2010, 17:22
DarkAndroid's Avatar
DarkAndroid DarkAndroid is offline
FRC #2014
DarkAndroid is an unknown quantity at this point
That's a bummer
But.....you can hang onto another robot with your design though....
Good Luck
11010110110
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
4 robots hanging ECarlson Regional Competitions 3 08-03-2004 00:27
Robots Hanging from the Floor Todd Derbyshire Rules/Strategy 16 13-01-2004 14:10
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Starting position and hanging clarification Don Wright Rules/Strategy 2 10-01-2004 14:21
