Go to Post As usual this was the programmers fault. - Swampdude [more]
Unread 10-01-2010, 13:08
bobylee's Avatar
bobylee bobylee is offline
FRC #2587
bobylee is an unknown quantity at this point
Suspension
The Rules is that you have to have contact with another robot. now it did not say you had to be elevated. so does that mean you can have a robot touching another robot, that is elevated? and you will still get 3 points?
Unread 10-01-2010, 13:19
lemon1324's Avatar
lemon1324 lemon1324 is offline
AKA: Arul S
FRC #2473 (CHS Robotics)
lemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of light
Re: Suspension
ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED.
SUSPENDED: A ROBOT only in contact with an ELEVATED ROBOT and/or a SUSPENDED ROBOT shall be considered SUSPENDED.
<G04> Scoring - b. Each ELEVATED ROBOT is awarded 2 points, or each SUSPENDED ROBOT is awarded 3 points.
To get the three points you would have to be off the ground and only in contact with a robot. It would seem, however, that you could be below the plane of the platform, and thus not ELEVATED, and still be suspended, as long as your only contact was with the robot you're hanging off of.
"I reject your reality and substitute my own"
Unread 10-01-2010, 13:20
Homsar66 Homsar66 is offline
AKA: Ryan
FRC #0122 (NASA Knights)
Team Role: Human Player
Homsar66 will become famous soon enough
Re: Suspension
The rules say you must be above the plane of the platform. So unless you can float, touching them while sitting on the ground won't count.
EDIT: ah he beat me^
Unread 10-01-2010, 16:08
blnace97's Avatar
blnace97 blnace97 is offline
FRC #2587
blnace97 is an unknown quantity at this point
Re: Suspension
But the Rules did not say that you had to be off the ground. all it said was "contact" and that means touching. it said they had to be contacting (Touching) another robot. it did not say that you had to be elevated.
Unread 10-01-2010, 16:14
crispey7's Avatar
crispey7 crispey7 is offline
None #2389
crispey7 is an unknown quantity at this point
Re: Suspension
the rules do say you cant touch anything else, so you cant touch the ground
Unread 10-01-2010, 16:17
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: Suspension
The rules are clear. You do not have to be above the plane of the platform to be suspended. You also have to be off the ground. It says only in contact with, and does not list the ground, so if you are touching the ground, and an elevated robot, you are not only touching an elevated robot.
On the flipside. Do not under any circumstances touch an allied suspended robot while on the ground (or not elevated) at the ned.
Unread 10-01-2010, 16:43
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Suspension
kirtar, There are a few 'not's in your statement that confuse me. Can you say it again differently? I'm re-reading the rules myself, but want to make sure I understand.
Thanks,
Edit: I re-read the rules and your post and they make sense.
A robot hanging from the tower above the platform level is elevated.
a robot that is only touching an elevated or suspended robot and nothing else is suspended.
if you aren't going to be elevated or suspended, get away from the tower.
Unread 10-01-2010, 16:50
Alumnus
Re: Suspension
Sorry about that.
To be elevated you must be touching your alliance's tower and be above the plane of the platform. No other restrictions on what you can touch.
To be suspended, the only things that you can touch are another suspended robot or an elevated robot. You can be at any elevation given that you are not touching the ground or any non-elevated/non-suspended robot.
Unread 10-01-2010, 17:32
Venturelli Venturelli is offline
FRC #1382
Venturelli is an unknown quantity at this point
Smile Re: Suspension
But it say you have to be ONLY in contact with a ELEVATED ROBOT and/or SUSPENDED
Unread 10-01-2010, 18:11
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Suspension
What about this scenario:
One robot A is ELEVATED. A second robot B gets SUSPENDED from A. A third robot C attempts to get SUSPENDED from A (or B), but ends up partially hanging from the robot and also still touching the floor and also touching the first SUSPENDED robot B. Is B still SUSPENDED, now that it is touching a robot that is touching the floor ?
Unread 10-01-2010, 18:17
FRC #1382
There is no point! because the rule says clearly that to be considered SUSPENDED, the robot can only touch a robot ELEVED and / or SUSPENDED
Chris is me's Avatar
AKA: Pinecone
Re: Suspension
I would say no, since it's not only touching another elevated or suspended robot.
Unread 10-01-2010, 18:59
Re: Suspension
That feels like an unintended consequence of the rules. Attempting to get additional hanging points results in reducing hanging points when those hanging did not 'lose their grip' I suspect this scenario is likely to occur at least once or twice in a tournament.
Unread 10-01-2010, 23:06
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Suspension
I believe in the given scenario only the elevated robot would score its 2 points, while the others would be touching something other than an elevated robot and would score nothing. However if the pile of robots shifted such that robot B contacted the tower and was held above 20" while robot A remained ELEVATED, the alliance would receive 4 points since robot B would still be considered elevated (above the plane of the platform and contacting the tower). C would still receive 0 of course.
This also brings up another potentially strategy: team A could build a ramp bot with a ramp/platform above 20". If they positioned themselves near the tower, teams B and C could drive on top of them and touch the tower with their robots. Both teams B and C would then be considered elevated and receive a 4 point bonus.
Unread 11-01-2010, 01:12
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: Suspension
Another idea is that a team could find a way to be on the platform then drape the poles with a cloth. Then any robot that hangs from the pole would only be touching the cloth and thus considered suspended. FIRST classically though does not like it when you use unintended loopholes though and will likely redefine suspension later in the season. I am reminded team 190 during Overdrive, they were able to complete legal hurdles without ever moving their robot. FIRST, as I recall, later deemed this strategy illegal.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
pic: Robot suspension joeweber Extra Discussion 11 15-01-2010 20:32
pic: Air Suspension joeweber Extra Discussion 23 30-12-2009 13:04
Mecanum Suspension? thefro526 Technical Discussion 4 09-01-2007 23:09
Mecanum Suspension Movement Rob2713g Technical Discussion 10 14-12-2006 19:22
Robot Adaptive Suspension Andrew Blair Technical Discussion 13 09-09-2005 12:02
