Go to Post I'm looking forward to seeing it in action! That is one sweet looking gun. The look on his face has me a tad worried though.... - Zholl [more]
Unread 10-01-2010, 18:19
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Flipping Bot
No can do: Definition in 8.2:
NORMAL CONFIGURATION – The physical configuration and orientation of the ROBOT when the MATCH is started. This is the state of the ROBOT immediately before being enabled by the Field Management System, before the ROBOT takes any actions, deploys any mechanisms, or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH).
(emphasis mine)
If you flip, you are no longer in the NORMAL CONFIGURATION that you were in at the beginning of the MATCH.
(since 2004)
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
info on 997 bot or 254 bot please! u2andllamasohmy Motors 16 11-11-2007 23:33
pic: Team 241: This Years Bot Lifting Last Years Bot Dantvman27 Robot Showcase 3 21-02-2007 07:04
Ramp bot vs. Arm bot SSMike Technical Discussion 49 22-01-2007 21:03
More flipping then expected cyberknights195 General Forum 6 07-03-2004 15:52
