Re: Cypress FirstTouch hex file?
[quote=chronon;895411]In the benchtop instructions we are told to go to where we downloaded the "FRC_IO.v1.hex" and select the "FRC_IO.v2.hex file", yet my team and I can't seem to figure out where those files are obtained from.QUOTE]
You only need the v2 file... the documentation has a typo where it references v1. As Greg said, it should be installed by the Driver Station Installer at: www.usfirst.org/frccontrolsystem then click on Mandatory Driver Station Update. This instaler can update the classmate or be installed on any other computer to run the driver station software. |
| creating hex file | seanl | Programming | 4 | 03-02-2007 22:08 |
| "Error.MCP" file after HEX file trans | iwdu15 | Programming | 1 | 24-01-2007 20:05 |
| Hex file downloads | Ryan M. | Control System | 2 | 29-10-2005 19:50 |
| hex file garbage? | sciguy125 | Programming | 2 | 04-07-2005 23:04 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
