Go to Post In 2001 instead of staring at the field at the game I turned around and watched the people watch the field. All I could see was a mass of people from all corners of the world, eyes lit up, gears turning in their heads. That, to me, is FIRST in action. - Jessica Boucher [more]
Unread 10-01-2010, 18:56
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question Bumper height v. height of "the bump"
Assuming I read and understand everything correctly:
Robot bumpers ought to be 5" tall, and must sit between the bumper zone of 10" - 16" from the floor. So bumpers would ride at their lowest from 10" - 15" from the floor and their highest at 11" - 16" from the floor.
"The bump" starts it's angle at the floor and tops/levels off at 12" from the floor.
So isn't it the case that everyone's bumpers will actually be higher than "the bump"? Significantly high on the top anyways? The robots in the demo video don't seem to be designed this way, although I 100% understand that video is just to get the idea across... for reference.
Since the wheels cannot extend outside of the bumpers, this is creating a funny picture in my head of a robot trying to successfully climb over "the bump"... I always sucked at math, so I guess the angle of the actual "bump", floor to top, is well designed to allow robots to climb it without having their bumpers get in the way. I dunno... I can't wait to get a practice bump built so I can see this first-hand.
Does anyone know the angle of the "bump" sides, floor to top?
Unread 10-01-2010, 19:12
Logan Cowley Logan Cowley is offline
FRC #1535
Logan Cowley is an unknown quantity at this point
Re: Bumper height v. height of "the bump"
as far as i know the bumps are 3 feet wide at the bottom and 1 foot wide at the top so that would give them an angle of 45 degrees.
Unread 10-01-2010, 19:21
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
45 degree slope, with a 1/2" transition from the carpet to the start of the bump slope.
Unread 10-01-2010, 20:26
Danakona's Avatar
Danakona Danakona is offline
AKA: Daniel
FRC #0597
Danakona is an unknown quantity at this point
Send a message via AIM to Danakona
Remember, the bottom of the bump is as wide as the platform. I don't remember all the numbers so I can't give you an exact number, but the top of the bump is 12 in and te height is 12 in. You can find the angle easily with a little trig.
Unread 10-01-2010, 20:27
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
I guess I was a bit thrown off by the thing, visually. 45 degrees makes near-perfect sense.
With the wheels being larger and bumpers being higher, I imagine robots would have no trouble, on paper anyways, driving up a grade such as this.
Unread 10-01-2010, 20:38
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Exclamation Re: Bumper height v. height of "the bump"
I'm surprised no one pointed this out, but the whole first part of my original post was BS. The tunnel is 18" tall, it would seem, and the top of "the bump" is actually about 20" tall from the floor.
SO. The top of the "bump" should indeed be taller than the bumpers on any robot.
This sorta doesn't make sense because shorter robots might not be able to see over the bumps in this case, correct?
Unread 10-01-2010, 20:58
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
You were right the first time - the top of the *bump* is 12" of the ground, with a 45 degree slope. The *platform* - the deck of the tower - is 20" off the ground.
You are right that most of the bumper will be higher than the bump. I used a 2D CAD sketch, with a bump and robot with bumpers, to analyze this issue - if you can also, that'd be great!
I discovered that if you build the bumpers at 10" (the lowest extreme) that you can use a tire size smaller than 16" to climb the bump. Surprisingly, tires larger than 16" will hit the bump with their bumpers first, rather than the tire. So, as long as you a tire smaller than 16", about as far forward as you can possibly design them, you should be perfectly fine getting up the incline of the ramp.
I do recommend doing this analysis yourself, if possible, because a robot with 4" tires - smaller than I think anyone would use - actually would need to have 10" of ground clearance to avoid "bottoming-out" on the crest of the bump.
If you have any questions, feel free to ask. Good luck to you and your team!
Unread 10-01-2010, 21:18
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Here is a drawing I made of the bump... If your not careful a robot could put their bumper right on top of the other robots bumper and be lifted when going up the ramp.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Bumper Height TeenDev Rules/Strategy 17 07-02-2009 11:35
Bumper Height Zultraranger Rules/Strategy 3 20-01-2009 23:57
Bumper Height? EricVicenti Rules/Strategy 9 14-01-2009 12:23
Center "Rack" Height Chris2 Technical Discussion 2 18-01-2008 20:02
"waiting for bump switch to be hit"???? Punjabguy87 Programming 10 19-02-2005 12:18
