Go to Post Trapping JVN (or any other IFI employee) is negative infinity [I]and[/I] a caption contest. Trapping 1114 is a measly 50 points, unless you trap Karthik, which multiplies your entire score by -1. - EricH [more]
Unread 10-01-2010, 20:40
ashoji12 ashoji12 is offline
FRC #2090
ashoji12 is an unknown quantity at this point
Spiral Drive
what if you had 4 independently rotating spirals as a drive train do you think that this would work?
Unread 10-01-2010, 20:42
Captain Fink Captain Fink is offline
AKA: Joseph Finkiewicz
FRC #1584 (Pirates)
Captain Fink is an unknown quantity at this point
Re: Spiral Drive
Sounds like it would work but could u draw a quick sketch? not quite sure what you mean
Re: Spiral Drive
Nobody's tested it yet, that I know about.
One caveat, and this may be the deal breaker: If it damages the carpet extensively, or is made of metal, it will not pass inspection. (<R08> governs traction items.)
It may be possible, but you'd have to test it.
Unread 10-01-2010, 20:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Spiral Drive
Like this?
http://www.youtube.com/watch?v=zBjlSJf4274
Unread 10-01-2010, 20:56
FRC #2090
Re: Spiral Drive
Originally Posted by squirrel View Post
yes that is exactly what i meant, kind of like those machines that shape half pipes in snow
but would this work like a crab drive?
Unread 10-01-2010, 21:09
MrForbes's Avatar
AKA: Jim
Re: Spiral Drive
My guess is that snow is one of the very few surfaces that that type of drive can work on. And since we don't see vehicles like that in common use on snow, it's probably not a very good idea.
But it is interesting
Unread 10-01-2010, 21:12
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Spiral Drive
It would work, but I would be concerned about the screws tearing up the carpet..
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 10-01-2010, 21:13
Re: Spiral Drive
Probably. But you're reinventing the mecanum wheel, to some extent.
Take a look at http://www.andymark.biz/mecanumwheels.html and see if those are pretty close to what you mean.
Unread 10-01-2010, 21:14
gorrilla's Avatar
AKA: adam spears
Re: Spiral Drive
should'nt these screws be way less efficient than a wheel?
Adam Spears
Unread 10-01-2010, 21:17
Re: Spiral Drive
Didn't say they wouldn't be. A screw like that would be like locking all the rollers on a mecanum wheel. (And then reducing the friction on said mecanum wheel, hopefully.)
Unread 10-01-2010, 21:35
Nurnburger Nurnburger is offline
FRC #0100
Nurnburger is an unknown quantity at this point
Re: Spiral Drive
It seems like one of the key elements is that its digging into the snow, so I doubt it would be very FIRSTable.
Unread 10-01-2010, 21:37
solopilot solopilot is offline
FRC #0293
solopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to all
Re: Spiral Drive
That is so cool... Thanks for sharing it.
Looks like something out of a old old James Bond movie.
I guess track drives are more functional.
Unread 10-01-2010, 22:10
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Spiral Drive
http://www.amazon.com/Tyco-Radio-Con.../dp/B00027P7RM
I have two of these at my house and have always wanted to make a larger one, but have never gotten around to it. Turning is not easy they have to tilt the screws and travel in an arc.
Unread 10-01-2010, 22:15
Re: Spiral Drive
For 1929 that is insanely impressive. Neat idea, I'd love to see it working on someone's robot within the coming weeks.
Unread 10-01-2010, 22:28
MrForbes's Avatar
AKA: Jim
Re: Spiral Drive
It might be allowed, but it's hard to say. The rule about what you can have in contact with the field seems to make it unlikely.
<R08>  ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be
purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed
to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no
case will traction devices that damage the carpet or other playing surfaces be permitted.
Traction devices shall not have surface features such as metal, sandpaper, hard plastic
studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep
one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not
use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or
Velcro-like fastener material is not allowed.
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
