Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 10-01-2010, 18:47
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
Macanum ability to climb ramps
My team and I were wondering how effective climbing ramps with mecanum wheels would be. I recall from years past they are not very good at climbing ramps, but I was wondering if you used encoders to set a certain speed if they would climb better. Thanks for the input.
Unread 10-01-2010, 19:14
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: Macanum ability to climb ramps
Our team was also throwing around this idea, as it would make the robot easy to maneuver/block balls from getting into your goals and to get to balls.
this is the major deciding point on our robot; Do we want to be able to go over the ramps, or do we want more maneuverability and be forced to fit under the passageway!
Have any teams tested Macanum wheels and their ability to make it over the "Hump"?
-McGurky
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 10-01-2010, 19:16
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
You might high center on the hump (this could also affect a 4-wheel tank).
Unread 10-01-2010, 19:34
Captain Fink Captain Fink is offline
AKA: Joseph Finkiewicz
FRC #1584 (Pirates)
Captain Fink is an unknown quantity at this point
ya my team is buying some, we have pretty much given up trying to get over the ramps, and going with a real low center of gravity with mecanum wheels, we see that it might not be to important to get accross the arena except at the end
Unread 10-01-2010, 19:40
I can think of two mecanum drives that could do it. 1322 has been playing with one that is specifically designed to climb ramps for a couple of years now: http://www.chiefdelphi.com/media/photos/32185
2826 has a slightly different method that may be more practical: http://www.chiefdelphi.com/media/photos/34306
Unread 10-01-2010, 19:46
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I played with some mecanum wheels a few years ago on a small scale and I was surprised with how well they climbed over objects. One of the things I did notice though was that the climbing was very Dependant on the surface on which they were climbing. Since the bumps this year are carpeted I would venture to say that a mecanum wheel-ed robot shouldn't have too many problems with climbing over the bump with the proper fame setup. (May require some suspension)
I know that I've been kicking around the idea with one of the students on my team and we think that a mecanum drive based upon the new C-Base for 2010 should be able to climb the bumps without too many problems with some creative weight placement.
Also, If I remember correctly, 357 used some custom mecanum wheels in 2006 and they were able to climb onto the ramp that year without too many problems...
Unread 10-01-2010, 19:57
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
These are both cool designs, and could be very useful this year. Unfortunately, it looks like the GDC doesn't want us to be that inventive:
<R11> The FRAME PERIMETER must be comprised of fixed, non-articulated structural elements of the ROBOT. The FRAME PERIMETER must remain a fixed, unchanging polygon throughout the MATCH.
Unread 10-01-2010, 20:00
Who said anything about these being in the frame perimeter? Remember, that's counted starting at 10" above the floor. It's not that hard to put a frame around the outside of these at that height, is it?
Unread 10-01-2010, 20:06
Alumnus
if you're not articulating the bumpers out of the bumper zone, there's nothing wrong that I can see.
In any case the first one seems valid since it's just a raised wheel.
Unread 10-01-2010, 20:09
Actually, it isn't. It's a full suspension. The omnis in the middle start out in a plane with the mecanums. They also happen to have a pivot point for the front of the frame, which can go up or down, sides independent. (In this picture, down; a few moments before, it would have been up.)
Unread 10-01-2010, 20:17
Robotbug's Avatar
Robotbug Robotbug is offline
Lovely user. =D
AKA: Kaela.
FRC #0753 (High Desert Droids.)
Team Role: Photography
Robotbug is an unknown quantity at this point
My team were throwing around ideas today. And an idea of a 2 part frame that bends in the middle to get over the humps would work really well.
It would have to use six wheels though. But getting over the humps would be easy. =]
Unread 10-01-2010, 20:38
karatekid's Avatar
karatekid karatekid is offline
AKA: Cole
karatekid has a spectacular aura aboutkaratekid has a spectacular aura aboutkaratekid has a spectacular aura about
My team was throwing around a similar idea-tank treads (on a smaller scale). I think this would be more effective especially for going over the ramps.
YOU JUST LOST THE GAME!
Unread 10-01-2010, 21:20
FRC #2081 (Icarus)
these are good ideas, especially the six wheel one. But how about just a standard four wheel mecanum drive train? I'm wondering if any teams tried this for 2006 or even 2007 and how they worked or if anyone saw how they worked.
Unread 10-01-2010, 22:09
dtengineering's Avatar
AKA: Jason Brett
It's not a 45 degree incline, by any means, but we got our mecanum to go up a ramp a couple years back. The first try didn't work, so we fixed up a few things (hence the clip of a student welding the frame) and then tried again.
The catch is keeping all four wheels in contact at the same time... but here's proof that a "standard" mecanum can climb at least a shallow incline. http://www.youtube.com/dtengineering...12/gyn9e0cT3-A
Jason
P.S. If you want omni directional drive ability, plus climbing... perhaps some form of crab drive is what you're looking for?
Unread 10-01-2010, 22:25
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
maybe for omni drive... Our Linkage might make a come back?
That would be awesome for me at least.. and I know some people on here liked it back when I posted it. If anyone is interested let me know I'll give out any details you need
Option to climb MikeReilly FRC Game Design 2 29-03-2009 15:15
[YMTC]: Robot Ability Taylor You Make The Call 29 07-04-2008 21:08
Toroid scoring ability sciencenerd Rules/Strategy 1 17-01-2007 11:30
Calculating Wheel Size To Climb Yan Wang Math and Science 12 18-01-2004 22:49
Robot Ability Database archiver 2001 4 23-06-2002 23:40
