Spiral Drive
what if you had 4 independently rotating spirals as a drive train do you think that this would work?
Re: Spiral Drive
Sounds like it would work but could u draw a quick sketch? not quite sure what you mean
Re: Spiral Drive
One caveat, and this may be the deal breaker: If it damages the carpet extensively, or is made of metal, it will not pass inspection. (<R08> governs traction items.) It may be possible, but you'd have to test it. |
Re: Spiral Drive
Re: Spiral Drive
but would this work like a crab drive? |
Re: Spiral Drive
My guess is that snow is one of the very few surfaces that that type of drive can work on. And since we don't see vehicles like that in common use on snow, it's probably not a very good idea.
But it is interesting |
#7
Re: Spiral Drive
It would work, but I would be concerned about the screws tearing up the carpet..
#8
Re: Spiral Drive
Probably. But you're reinventing the mecanum wheel, to some extent.
Take a look at http://www.andymark.biz/mecanumwheels.html and see if those are pretty close to what you mean. |
#9
Re: Spiral Drive
should'nt these screws be way less efficient than a wheel? |
#10
Re: Spiral Drive
Didn't say they wouldn't be. A screw like that would be like locking all the rollers on a mecanum wheel. (And then reducing the friction on said mecanum wheel, hopefully.)
#11
Re: Spiral Drive
It seems like one of the key elements is that its digging into the snow, so I doubt it would be very FIRSTable.
#12
Re: Spiral Drive
Looks like something out of a old old James Bond movie. I guess track drives are more functional. |
#13
Re: Spiral Drive
http://www.amazon.com/Tyco-Radio-Con.../dp/B00027P7RM
I have two of these at my house and have always wanted to make a larger one, but have never gotten around to it. Turning is not easy they have to tilt the screws and travel in an arc. |
#14
Re: Spiral Drive
Re: Spiral Drive
It might be allowed, but it's hard to say. The rule about what you can have in contact with the field seems to make it unlikely.
<R08> ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed. |
| crab drive vs. mecanum drive system | superbotman | Technical Discussion | 33 | 06-01-2010 03:09 |
| Drive Train Components: the inner working parts of a drive train | naruto137 | Technical Discussion | 3 | 10-12-2008 21:14 |
| Chain drive vs. cogged belt drive(timing belts) | LordBritten | Technical Discussion | 24 | 20-12-2006 23:07 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
