Go to Post To me, the changing rules are a big part of the fun. If the rules stayed the same year to year, robots would start to look the same. That would be boring. - Richard Wallace [more]
View Poll Results: Vision Tracking: Did the GDC get it right this year or not?
Yes, they got it! This is the year. 27 55.10%
No, Another disappointment. Maybe next year... 22 44.90%
Voters: 49. You may not vote on this poll
Unread 09-01-2010, 21:37
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: Vision tracking: Did they get it right?
Anyway I can find the Java camera code? I saw it once somewhere, but can't remember. Thanks in advance!
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 09-01-2010, 21:47
GGCO's Avatar
AKA: Grant
FRC #3357
http://first.wpi.edu/FRC/frcjava.html
Nevermind.
The FIRST Alliance
COMETS Robotics
Website
Unread 09-01-2010, 22:12
Chris is me's Avatar
AKA: Pinecone
Originally Posted by jspatz1 View Post
Not necessarily. A defensive bot's autonomous mode may be to block a goal.
Nope. Penalty for crossing the white line and penalty for each game piece the robot touched.
Unread 09-01-2010, 22:19
Actually, it's a double penalty for crossing, double penalty + yellow for the first ball/robot hit after crossing, and double penalty per contact after that. That was a nice understatement, Chris.
But there is a goal on your side of the line that you could block.
Unread 10-01-2010, 21:40
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
fabalafae is an unknown quantity at this point
Is there any starter camera tracking code for LabVIEW yet? I looked through the examples, but those are only for color recognition- not for shapes.
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
Unread 10-01-2010, 21:58
Paradise1165's Avatar
Paradise1165 Paradise1165 is offline
FRC #1165
Paradise1165 is an unknown quantity at this point
perhaps. this year doesnt so sound so imortant or controlable this year. if we had this camera last year and these cool little laptops, yeha this would make it a whoooooooooooooole lots better.
Unread 10-01-2010, 22:26
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The starter code for LabVIEW is actually built into the default template. This means that when you create a new robot project, it already contains some sample vision code for finding the target.
Unread 10-01-2010, 23:23
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
The LabVIEW off the CD does not have it (probably to keep the people compiling the CD from getting a hint about the game early). You have to download the update here: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
I think that, because the targets are stationary rather than moving like last year, there is definitely an opportunity to score in autonomous using the camera to track. Long range shooting was impossible last year because of the moving targets and the unpredictable floor, but this year I can see it make a comeback (although it might have been nice to see a point increase for a long range goal... sort of like a 3-pointer in basketball. Oh well...)
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 11-01-2010, 22:55
TD-Linux TD-Linux is offline
FRC #2530
TD-Linux is on a distinguished road
I've only looked at the C++ vision code so far, but I would imagine the labview code to be similar.
I am going to test it tomorrow with the old robot, but there are a few things that worry me:
- While the ellipse detection only uses luminance data for detecting edges, it does so by allocating memory, mixing the image down, processing it, then freeing the memory. I don't know how efficient vxworks' malloc is, but this seems like a rather bad idea.
- From what I can tell, the ellipse detection uses the edges of ellipses - meaning that it will detect two ellipses around the inner and outer edges of the black circle. While this is perfectly acceptable when one bases navigation of the center of the circles, it has to potential to throw a wrench into distance algorithms (e.g. inverse perspective transform). Some sort of algorithm will be needed to pick one of the edges (preferably the outer one).
- The tracking algorithm only samples the image once, then bases all further turning on the gyro without sampling any more images. There are both problems with this approach, as well as problems in the implementation. I won't elaborate on this point, as it probably deserves its own separate thread.
I'm impressed that they created a decently working camera example for teams to start with, though it definitely is not a perfect solution. I have to wonder if they did this on purpose - after all, it would be no fun if everyone's robot ran the same code.
Unread 12-01-2010, 00:17
You are absolutely correct. And no... malloc on VxWorks is not amazingly fast or anything. It is a bad idea and any patch you'd like to submit to address the issue would be greatly appreciated. I hear the AxisCamera2010 does the same thing, but with C++ new! (hint hint)
This is intentional... when you are moving, your image is usually very blury, meaning that you are unlikely to be able to find high contrast edges. By using the gyro, you are able to get higher bandwidth data to move you pretty close to your target. Since your target is not moving, you will likely be pointed very close to the target when the gyro is at the detected angle and the next update will be a minor adjustment.
This method is more reliable and typically faster when homing in on stationary targets.
If you'd like to discuss it further, feel free to start another thread.
-Joe
Unread 12-01-2010, 11:22
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
I'm really excited for this year. Live video streams to the drivers will be amazing, and the targeting is built into the API (through their ellipse-finding code). Now teams will have consistant, (hopefully) reliable, and contained targeting code that's standard across the board.
Unread 12-01-2010, 14:43
davidalln's Avatar
World's Worst Coder
AKA: David Allen
Correct me if I'm wrong as I don't have the code in front of me, but doesn't the example find the target based on locating two concentric ellipses and then find the data such as the height and width and (x,y)? Therefore, the target will essentially act as one circle that can be used for distance algorithms.
Unread 18-01-2010, 20:40
rjbarra rjbarra is offline
GameTime
AKA: Joe Barra
FRC #0020 (Rocketeers)
rjbarra is just really nicerjbarra is just really nicerjbarra is just really nicerjbarra is just really nice
It uses RobertDrive class which does not support crab drive
Unread 18-01-2010, 21:53
Since it is not possible to support all type of robot bases with the current WPILib, it controls what is probably the most common. At one level it computes an angle to rotate, then uses robot drive to rotate. It should be pretty easy to map to alternate drive bases. Of course you will likely want it to move forward, kick, line up with another, etc.
Greg McKaskle
Unread 18-01-2010, 22:58
President, VEX Robotics, Inc.
Is vision needed in this game?
Is the goal stationary? YES
Do you know the location of the balls prior to Auton? YES
Do you know your robot location prior to Auton? YES
Is there potential defense in auton? NO
Can a human score without camera? YES
Is vision needed in this game? NO
We are all for using the camera, when the effort is worth it. We used it in 06, because it was worth it. We will not use it this year because it is not worth it.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Is fedex right? did ship get delayed for central Mass? Joe G. General Forum 7 21-02-2009 19:38
So what did we get right? geeknerd99 Chit-Chat 9 10-05-2006 13:11
71's Vision Tracking Problems Bill Beatty Rumor Mill 7 19-04-2005 17:41
did they Jgreenwd1 Championship Event 1 29-04-2002 11:45
They got it right in LA (Times)! dlavery Regional Competitions 0 10-04-2002 15:26
