Go to Post "Why use a CNC when you can get it done with wood, duct tape, and zipties!" - gcgeobuff [more]
Unread 09-01-2010, 18:01
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
Anyone else's serial number not working?
I just tried activating LabVIEW to start programming, but when I go to enter the serial number provided in the sleeve, the activation program continuously says the number is not valid. I understand I might have to ask at NI about fixing this, but I was wondering if anyone else was having this issue.
Unread 09-01-2010, 18:17
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Re: Anyone else's serial number not working?
Haven't tried it yet.... I hope it's something not widespread.
Unread 09-01-2010, 18:20
brianafischer brianafischer is offline
FRC #0503 (Frog Force)
brianafischer is on a distinguished road
This item is addressed in the Mandatory Update:
Do not use the serial number that comes in the software kit for activation. You MUST use the following Serial Number to activate LabVIEW:
L13R00000
There are two updates that are necessary
1. FIRST Robotics Software 2010 - Windows - LabVIEW & NI Utilities
2. FIRST Robotics Software 2010 - Windows - Driver Station
Just an FYI, the zip file password is "Breakaway4FRC!"
Unread 10-01-2010, 12:09
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
When I try to extract the zip files it gives me an error that the file is empty, and never gives an option to put in a password. Is there a certain extractor that is suggested for doing this?
Unread 10-01-2010, 12:48
I reccomend 7-Zip. It is open source and can handle more formats than winzip:
http://www.7-zip.org/
Unread 10-01-2010, 12:58
DavidGitz's Avatar
Thanks for the tip. I tried using the 7-Zip program and put in the password as was said above, but I get the error "Can not open file as an archive". Can somebody check to make sure the file listed at the site is still good?
I should note, I have the same problem with the National Instruments LabView update.
Unread 10-01-2010, 19:53
jescholler jescholler is offline
FRC #0093
jescholler is an unknown quantity at this point
I'm not sure what's wrong with the driver laptop, but the extraction worked on my home PC with the Windows extractor.
Unread 10-01-2010, 20:58
Just re-downloaded the file and no problems here. I would do the following:
1. Re-download the file. It should be a fairly large file (188MB), verify the file size after the download is complete.
2. Make sure you extract to a directory you have permissions to access
Unread 10-01-2010, 22:16
Paradise1165's Avatar
Paradise1165 Paradise1165 is offline
FRC #1165
Paradise1165 is an unknown quantity at this point
use the password from the decription code:
Breakaway4FRC!
Unread 10-01-2010, 23:50
DavidGitz's Avatar
I am downloading the legitimate LabView update now but the Driver Station update is still having the same problem. I just tried downloading the Driver Station update with Firefox (I was using Chrome) and it's working fine now. When I downloaded it before the DS update was about 30 MB, as was the LV update, now it is up to 116 MB. Good times.
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
So, Anyone Else's Flight Canceled Chris Marra Championship Event 37 16-04-2007 13:49
Anyone else's parents... c-squared_2006 Chit-Chat 5 28-01-2006 21:11
Serial Number? Drok00 LabView and Data Acquisition 2 09-01-2006 20:39
USB to Serial -- Working Device Found! Eko Programming 10 23-02-2004 12:56
